Help!!!!!!!!!!!!!!!! 50 hour screwed up
/ Help!!!!!!!!!!!!!!!! 50 hour screwed up #1
Tractor_Jim_CT
Connecticut
BX23
I started the last part of my 50 hour service today and I really messed up on this part.
See Photo:
A: Hydro transmission oil filter removed (no problem)
Looking at the Kubota manual an the picture shows the transmission drain plug under the filter. There are two large bolts where the picture shows the drain plug that did not make sense. (I'm a visual learner)
B: I filgured what harm to remove plug B in picture next to removed filter. A little fluid drained out and I thought not the plug, but did get a little extra fluid out, since the all seemed to lead to each other.
C: With no harm done on B: I move to C: I noticed a spring that shot out and said to my self, "Oh ****"
I picked op the screen from the oil pan, pushed/ quided it back into the hole and replaced the bolt. Concerned I looked over my manuals and couldn't find if I replaced this correctly. I got to thinking I better look at the oil pan a I noiced a metal ball bearing and I "Oh ****" again.
see next post
Here's a picture of the parts from point C:
The arrow show the direction of how I replaced these parts.
The ball bearing was placed on the top of the spring and quided back into the hole, washer, then bolt.
Did I replace this correctly. I don't want to put the new hydro fluid in, etc. until I know I did this correctly. I now question how nothing came out of plug B: ..the ball was so small, I'm sure it came from C: with the spring.
Another picture
Another
Yes I did find the drain plug, but also wanted to show this $5 pan I got at Lowes that fit perfect for change. Wipes clean for future use
Last picture..wanted to show filter removal pliers that worked well from Pep Boys Auto.
/ Help!!!!!!!!!!!!!!!! 50 hour screwed up #7
Just my .02$, but it appears there is a smaller or tapered end on the spring. I would think that end woud be the ball side. I definitely would like to hear from others.
/ Help!!!!!!!!!!!!!!!! 50 hour screwed up #8
looks like a little check valve for the filter
/ Help!!!!!!!!!!!!!!!! 50 hour screwed up #9
I sent a PM If you email me your email at that address I wil email you the parts book for a bx 22 it appears to be the same.
Cleaned the hydro screen. Had very little metal fragments. Replaced the Hydro fluid and filled the fluid.
Started tractor, let run for a few minutes. The FEL worked perfect. No leaks anywhere.
50 hours is done. Thank God.
Still would like some reasurance on the spring and ball issue.
/ Help!!!!!!!!!!!!!!!! 50 hour screwed up #11
First the ball goes in, then the spring, washer on bolt and thats it. While I do not have yoour tractor model, it would indeed appear to simply be a bypass for the filter should it ever become ocluded and develop enough pressure to press the steel ball against the spring load enough to simply move oil through that passage. I have on many occasions pulled out similar bolts with a spring an steel ball. Our JD ZTR comes to mind. You will be fine.
Thanks RaT California...That's what I needed to hear.
Now that I've done the 50 hours..clean and waxed the tractor,
I'll be glad to simply climb in the seat and start using it.
Now let's see how I hold it together when I setup the 3 point hitch for the 1st time.
/ Help!!!!!!!!!!!!!!!! 50 hour screwed up #13
Sounds like it's time to sit back and have a cool one now that the job is done... /forums/images/graemlins/smile.gif
Next time it will even be easier...one less bolt to remove... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Looking back on the day I definitely have to agree, next time one less bolt.
/ Help!!!!!!!!!!!!!!!! 50 hour screwed up #15
Jim, for next time here is an exploded parts manual for your BX, courtesy of tractorsmart.
Click above on the underlined tractorsmart, it will lead you to a web page where you can download the parts manuals for your BX and accessories. They are pdf files and you need Adobe Acrobat reader to read them.
In the unlikely event you don't have Acrobat reader on your computer get one free at Adobe.com. It's really a valuable accessory for lots of information on the net.
Hi V8Dave,
I just searched the link and attached is the section I had a problem with. I had this link and did not think to use it.
Thanks for the advise and allowing me to confirm visually it when back together correctly.
AGRIC AFMJ65 - 65" ROTARY TILLER (A64277)
AGRIC AFMJ65 - 65"...
2004 Chevrolet Trail Blazer 4x4 SUV (A64557)
2004 Chevrolet...
32" Smooth Lip Mini Bucket  (A62679)
32" Smooth Lip...
Kobelco SK135SRLC-1E, Cab, Heat/Air, Manual Thumb8 (A62679)
Kobelco...
New 11'x19' Steel Carport with 10' open sidewalls  (A62679)
New 11'x19' Steel...
2016 CATERPILLAR D6K2 LGP CRAWLER DOZER (A65053)
2016 CATERPILLAR...
