Help 3400 3 point wont move
/ Help 3400 3 point wont move #1
banjopkr
Washington, The Gorge
Kubota L3400
Hi all,
I was using my blade to move snow today and after an hour of working the three point up and down the lever "broke free" from whatever it was attached to. In other words I can freely move the leverback and forth and I cant tell if it used to be attacheed to somthing. Any help would be great.
Thanks
/ Help 3400 3 point wont move #2
banjopkr said:
Hi all,
Thanks
have a quick look down where the lever moves and look for anything obvious, move the lever up and down and see if the shaft into the lift control valve moves, if it does call the dealer. unless you have a bit of mechanical know how, dont dig any futher as it can get a bit confusing.
/ Help 3400 3 point wont move #3
I don't know it you have a gear or HST model.
On the HST the lever goes into the transmission case. If you look from the rear and have someone move the lever you may be able to see if the pin fell out. If everything looks OK you should call the dealer next. I have not heard of this problem yet.
How many hours do you have? Is it a gear or HST?
Keep us informed as to what happned and good luck. I hope it is simple to fix.
Hey thanks for the replies. After I removed the shroud under the seat I discovered that the pin had fallen out an easy fix thankfully.
Thanks again!
/ Help 3400 3 point wont move #5
Thanks again!
Thanks for the update, Tha'ts great news!
Unverferth Perfecta 12 (A64126)
Unverferth...
Valley Model 8000 Irrigation System (A62180)
Valley Model 8000...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7731 Miles (A63688)
2019 Cadillac XTS...
2019 Dodge Durango SUV (A61574)
2019 Dodge Durango...
2022 EZ-GO ELITE...
Farmall Cub Tractor (A62613)
Farmall Cub...
