Hello
/ Hello #11
Checked tire pressures and lubed all the steering points. Removed front dust covers and cleaned. Still having the issue of not turning left.
Please clarify. Do you mean when you try to turn thevsteering wheel to the left that the front tires don't turn tonthe left . . . Or donyou mean the tires do turn to the left but thr tractor resists going to the left ???
/ Hello #12
Grassman - OK.
there is a cable that runs directly from the front l/h axle pivot directly across to the front r/h axle pivot - you can see it when you have BOTH of the dust shields removed. Sometime one end or the other of that cable works loose and jams the steering in such a way that you can only turn in one direction or drive straight ahead. Check both of those connections closely with both dustcovers off - let us know.
/ Hello
Just slow when turning left. Grass cutting season is over so I now have time to fix my problem.
2019 Freightliner B2 School Bus (A59230)
2019 Freightliner...
DOOSAN 7K FORKLIFT GS35-5 (A60736)
DOOSAN 7K FORKLIFT...
2007 Ford Explorer 4X4 SUV (A59231)
2007 Ford Explorer...
48x4 Mini Skid Trencher (A61307)
48x4 Mini Skid...
2000 REITNOUER ALUMINUM FLATBED TRAILER (A60736)
2000 REITNOUER...
Toyota RF1-SD1X45 4,500 LB Stand-On Electric Forklift (A59228)
Toyota RF1-SD1X45...
