Cylinder head removal CH18S
   / Cylinder head removal CH18S
I ordered the specified gasket kit for the 18HP (24-841-01-S) and it's on the way. Guess I need to stick with that, and hopefully those have improved over time. I gather you are saying the new design would not work on the 18HP. Just hoping I might be able to avoid future blown gaskets best I can, on an engine known for blowing gaskets.
I ordered the specified gasket kit (OEM) for the 18HP (24-841-01-S) and it's on the way. Guess I need to stick with that, and hopefully Kohler has improved those significantly over time. Just hoping to avoid future blown gaskets best I can, on an engine known for blowing gaskets. Wish they made one of those nice beefed-up gaskets for the 18HP.
   / Cylinder head removal CH18S #13
You would have to have them both there to know I suppose. They blow between the cylinder and oil return holes. The stock gaskets seem to have enough area there.
Well, I had both head gaskets replaced, all valves lapped and new valve seals installed, and replaced breather reed and gasket. Pistons and bores looked good except for carbon build-up as expected. Seemed to be all set, until I got the deck back on and mowed. After about 5-10 minutes, started smoking again, plugs fouled and then heaps of smoke, as bad or worse than before. Went through lots of oil in a few minutes.
Did a leak-down test, which I should have done up front. It passed with 11% leakage on one cylinder and 13% on the other. Hardly any audible hiss anywhere. I am perplexed. No smoke coming out of breather tube, and zero oil. Changed the oil and filter just as a "why not" move, and smoking actually got worse.
Thinking right now must be oil wiper ring. Any thoughts? Given probable cost to do new rings on a 25 year old engine with probably 1600 hours or so on it, may be looking at a re-power situation. If so, can't say I didn't get my money's worth from the old engine.
Also, any ideas on what the source of the oil might be? I thought about the fuel pump (mechanical), as a membrane separates the fuel from oil in the valve cover. All I can think of. Fuel flow is fine however.
If I have to re-power, wanted to ask has anyone here repowered a cub cadet 2185 / CH18S? If so what engine did you use and how did it go?
I see a "plug and play" 25HP command replacement for the CH18S out there. I don't need more power, and it runs around $3,500. Wondering if a CH640 could work, and if so what spec I would need. Same service manual for both CH18 and CH640 , so seems, to one with limited knowledge on the subject anyway, that would be an option. PTO shaft larger though, near as I can tell.
   / Cylinder head removal CH18S #16
I'm assuming that your oil shows no signs of fuel as the level is ticking down? Oil checked with the cap resting on top, but not screwed on the tube? Yes, fuel can transfer from the pump and also a carb issue such as float valve or the accelerator pump if equipped. The latter you will have a much more pronounced rich condition, black smoke etc.
You didn't mention what you found when you had pulled the heads off? How'd things look and you assembled according to the sheet?
It may be tough to see the smoke from the breather, so temporarily vent it outside. A strange thing that I've had happen on horizontal twins that had breathers that did blow oil mist were exasperated by another external leak, the dipstick seal.
It could be good to know if you are pressurizing the crankcase or not. I don't suppose that you have a manometer laying around? I wonder if you could do the glove test on this?
Appreciate the input.
Faint smell of gas in oil. No indications of rich mix or unburned gas. No black smoke at all. Have had carb float issue you mentioned in the past. Not that. Agree there must be elevated crankcase pressure to have oil being pushed into the combustion chamber. Haven't done balloon but pretty sure what result would be. The question for me at this stage is the route, not so much the cause.
I didn't do the head gaskets, but the guy that did has done it many times for many years. No reason to suspect an ongoing issue there. He also replaced breather reed and gasket. Also, I tried diverting the end of the breather tube outside the air-filter housing away from the carb. as you suggested. Had no effect. Plus no oil even on the end of the tube. Breather system looks solid.
Fuel pump strikes me as one remaining possibility, but again, having no fuel-flow issues. Other than the fuel pump, that leaves the rings near as I can tell. Leak-test good, but maybe the oil-wiper ring is letting oil through. New gaskets, seals and lapped valves make combustion chamber tighter than before and maybe that's why it's gotten worse (more stress on rings, more differential pressure along sides of piston).
Bottom line is if oil is getting past the pistons and rings, regardless of the root cause, I need to re-power it. Time needed and cost of having rings done on a machine with that many hours not worth it relative to cost of a new engine, especially as it's early in grass-mowing season and here I sit with several acres.
Got my money's worth and more from the engine. Have seen CH18S's for around $1,400, supposedly in stock. May be my best option.
Thanks again.
(2) Goodyear 18.4-38 Tires (A53316)
(2) Goodyear...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A51692)
2013 International...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A55302)
NEW 2025 Load...
2016 Ford Explorer 4WD SUV (A55758)
2016 Ford Explorer...
2017 International DuraStar 4300 24ft Box Truck (A55788)
2017 International...
2021 KENWORTH T270 24FT BOX TRUCK (A56129)
2021 KENWORTH T270...
