Hello
/ Hello #1
VAKubotaGal
Charlottesville, VA
Kubota BX 2660
Hi. I am just writing to introduce myself as I just joined TractorbyNet at the suggestion of a tractor owning friend. I recently purchased a used 2009 Kubota BX 2660. I have been wanting a tractor for years and have endured a mountain of skepticism and resistance from my husband. Nonetheless, I bit the bullet and bought a Kubota. I think I got a good deal. The tractor has about 150 hours on it with only superficial flaws. The package included a 60 inch MMM, Kubota FEL, Woods box blade and a rake. I'm a bit intimidated by the maintenance required but will re-read the manual to make sure I do all the right things. I enjoyed clearing our 200'+ driveway after the two substantial snowfalls this past month. I'm looking forward to several projects on our 4 acre plot including grading and re-graveling the driveway.
My Dad, who was great with mechanical things, passed away last year. He would have LOVED this tractor. I really miss his support, help and advice. I will likely be relying on this forum for assistance. Any advice/suggestions you can offer up front would be appreciated. Thanking all in advance.
Mary Beth
/ Hello #2
Hello back. I think it's funny that you had to talk your husband into getting a tractor. Usually, it's the other way around.
/ Hello #4
:welcome:
To TBN from Alabama. I would have thought that your husband would have been trying to talk you into getting a tractor. I guess he is already busy doing something else. With 4 acres, you surely need a tractor.
/ Hello #5
Hi welcome form Kansas. After awhile you will have to get up early to keep your husband of the tractor. The BX series are little dynamos. You will be amazed at what they can do.
Have fun with it.
/ Hello #6
Welcome. Yeah, this role reversal is a little unusual. My wife is finally warming up to the tractor. No, that isn't exactly correct....she just doesn't oppose it quite as much as she did. In time.
/ Hello #9
Welcome from the Adirondacks. :welcome: You wouldn't get any grief from hubby if you lived up here in Snowville USA. I spent much of the past 3 months plowing with the tractor. You will enjoy it for sure this summer.
/ Hello #10
Welcome! I'm jealous - I have an older BX2350. Up front advice, eh? Other than checking fluid levels, keeping the radiator screen clean and scheduled maintenance, the only "watch out" issue that I can think of is potentially damaging the transmission cooling fan. Be careful not to let a stick run up under the belly (any time, but particularly without the mower deck on), and end up poking the plastic fan. It's in the back of the tractor, in front of the transmission, way up underneath.You can get guards for that if you're going to be running around a lot a fallen branches or through fields with trees. Me? I'm just VERY careful in the woods.
The two fuel filters are a bit undersized, and can collect enough water to completely block them if the water freezes. Many have experienced issues with that, including me - more than once. I suggest good fuel, and changing the filters just before winter if you regularly get cold temps. You can run additives, but they're somewhat controversial - some brands will cause premature wear, so I avoid it. If you keep it in a heated garage, well, you may never experience the issue even with a water soaked filter. You won't be outside long enough for it to freeze!
The front tires are prone to leaks, being made of relatively thin rubber (and my tire beads won't seal). If you have issues, have tubes put in them.
So, one issue that could cost you money (fan damage), and two that'll just frustrate you, but not harm the tractor.
The front loader WILL get you in trouble if you don't have rear counterweight (box blade). Be super careful on side slopes with the loader attached - avoid side slopes if possible. NEVER go down a hill unless you're in 4WD! You can sometimes get away with it if you have an empty bucket, but don't risk it. Wear your seat belt and keep the ROPS on/up. Watch those low branches... You duck, the ROPS hits the branch, branch swings forward and pushes hard against your back or head. I've learned the hard way, and it took a few lessons!
With maintenance, you can't hurt that tractor, but it can hurt you if you don't respect its weight and power. (I don't mean to scare you.)
Congrats on your purchase, and welcome aboard!
/ Hello #11
Welcome to the forum.
Now all you need is an RTV to go along with the tractor. Perhaps your hubby will like that idea better? It is a back saver.
Have fun, be safe!
1995 Landoll Trailer, VIN # 1LH17AUHXS1007250 (A65563)
1995 Landoll...
2006 MINI Cooper Convertible Coupe (A61574)
2006 MINI Cooper...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
2012 Kenworth T800 (A64127)
2012 Kenworth T800...
2019 Nissan Sentra Sedan (A61574)
2019 Nissan Sentra...
FIRMAN H07553 GENERATOR (A64276)
FIRMAN H07553...
