Hello From Frankfort Il
/ Hello From Frankfort Il #1
Doneal
Frankfort
Kubota B1700
Have a Kubota B1700 . Ive had it about three years and think it must of had a low compression when I got it because it had starting issues in cold weather. Late this winter would not start, even when the weather turned warn. Found compression to be 230# in all three cylinders, so im in the process of trying to fix it in frame, new rings, probable pistons and bearings.
thanks for any help Dan
/ Hello From Frankfort Il #2
:welcome:
To TBN Dan. How many hours on it? Have you tried running a compression test yet?
/ Hello From Frankfort Il #3
Hi, Dan. Welcome to the forum. :welcome:
I'm going to move your thread over to the Kubota section to see if we can get you some more input on that problem.
Yes, 230 PSI in all 3 cyl. Dealer says should be 450,psi and that when it gets in the 230 to 250 range, hard start to no start.
Yes, 230 PSI in all 3 cyl. Dealer says should be 450 psi and that when it gets in the 230 to 250 range, it's a hard start to no start.
BOX OF MISC (A63745)
JOHN DEERE 825 - 4R DANISH TINE CULTIVATOR (A63290)
JOHN DEERE 825 -...
1980 FORD A66 WHEEL LOADER (INOPERABLE) (A63569)
1980 FORD A66...
1999 John Deere 345 Lawn Mower (A63116)
1999 John Deere...
2012 MACK CHU (PINNACLE) (A63569)
2012 MACK CHU...
2022 GREAT DANE CCC-3314-21053 53X102 T/A DRY VAN TRAILER (A59910)
2022 GREAT DANE...
