Hello from Arkansas
   / Hello from Arkansas #11
Welcome to tractorbynet. :)
Chad
   / Hello from Arkansas #14
I think you will find it calls for Trans-Hydraulic Fluid for Case/International Harvester.being overfull and wrong fluid might be cause of noise.I would drain it and start over.
Okay I can do that. Where do I drain it from? Underneath there are 3 big screws I know the front end is oil. Is the back 2 where I drain it from?
   / Hello from Arkansas #16
hydraulic oil runs transmission and for Brakes and your loader.I have never drained mine so I am not sure.I would say you are right.I have my tractor about 5 years and it was changed when i bought it.
   / Hello from Arkansas #17
just guessing ist plug would be transmission and second would be Brake system,
I've been searching several sites and the one about 454 says they have 2 transmissions one for high low gears and 1-4. So I will locate the transmission oil and then drain it. Thank you I'll let you know what happens
   / Hello from Arkansas #19
I will be watching for your post, Ron
   / Hello from Arkansas #20
I have the service Manual for INT2400B on Disk PDF file.
4-295/75R22.5 Tires And Rims (A50775)
4-295/75R22.5...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
2015 Ford Escape SUV (A55758)
2015 Ford Escape...
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
35in Excavator Tooth Bucket (A55787)
35in Excavator...
40' CONTAINER (A51244)
