Hello from Arkansas
   / Hello from Arkansas #11
Welcome to tractorbynet. :)
Chad
   / Hello from Arkansas #14
I think you will find it calls for Trans-Hydraulic Fluid for Case/International Harvester.being overfull and wrong fluid might be cause of noise.I would drain it and start over.
Okay I can do that. Where do I drain it from? Underneath there are 3 big screws I know the front end is oil. Is the back 2 where I drain it from?
   / Hello from Arkansas #16
hydraulic oil runs transmission and for Brakes and your loader.I have never drained mine so I am not sure.I would say you are right.I have my tractor about 5 years and it was changed when i bought it.
   / Hello from Arkansas #17
just guessing ist plug would be transmission and second would be Brake system,
I've been searching several sites and the one about 454 says they have 2 transmissions one for high low gears and 1-4. So I will locate the transmission oil and then drain it. Thank you I'll let you know what happens
   / Hello from Arkansas #19
I will be watching for your post, Ron
   / Hello from Arkansas #20
I have the service Manual for INT2400B on Disk PDF file.
2017 Nissan Versa SV Sedan (A53424)
2017 Nissan Versa...
Houle 48-6D-5250 Manure Tanker (A50775)
Houle 48-6D-5250...
2020 Case TR310B Skidloader (RIDE AND DRIVE) (A50775)
2020 Case TR310B...
2014 Nissan NV200 Cargo Van (A55788)
2014 Nissan NV200...
