Heavy Roller
/ Heavy Roller #31
No, there is no way the Kubota will lift it.
I will try with my tractor that is about 3 times the size of the Kubota.
Not even sure it can handle it.
If it doesnt, I will try to get the large commerical loader at the plant to do it for me.
I plan on putting it on a tandem 16' trailer, which will still be a load, But I have previously put 2 yards of wet concrete on it (much overloaded /forums/images/graemlins/frown.gif) and I only have 1/2 mile to go.
/ Heavy Roller #32
I wouldn't use deisel.... That will be a solvent for the asphalt... An easy waterer is a 1/2" pvc pipe suspended across the top o fhte roller perferated. This connected to a hose, then a dump valve, then a resevoir. If small jobs.. a small res'vr will do.. perhaps a peice of 4" pvc capped at ends just above the 1/2 pipe..
For a scraper.. some use a peice of fence stretched across the drum, held in place with enough resistance that it will clean the drum off.
Not the best bet.. but if your drum has ridges.. a scraper blade will be more challenging...
Soundguy
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
Giyi XKH39 (A60463)
Giyi XKH39 (A60463)
20FT X 30FT ALL STEEL CARPORT (A58214)
20FT X 30FT ALL...
1987 FORD F-700 FUEL TRANSPORT TRUCK (A58214)
1987 FORD F-700...
2021 CATERPILLAR 259D3 SKID STEER (A62129)
2021 CATERPILLAR...
KUBOTA U55-5 EXCAVATOR (A59823)
KUBOTA U55-5...
