Heavy equipment specs???
/ Heavy equipment specs??? #1
Tags
Platinum Member
Connecticut
BX2360/ Kubota SVL90-2/ Kobelco 115SR/ Takeuchi TB260
Does anyone know if there is a spot on the web to find equipment specs??I am looking for specs on a JD 244E or H wheel loader and am not having much success,any help would be greatly appreciated.
/ Heavy equipment specs??? #2
Here is the link to the JD website with the specs.
<A target="_blank" HREF=http://www.deere.com/en_US/cfd/construction/deere_const/docs1/noncurrent_loaders.html>244 Specs</A>
I think the 244 series has been replaced by the 304 if you are looking for a new model.
<A target="_blank" HREF=http://www.deere.com/en_US/cfd/construction/deere_const/wheelloaders/304h_construction_general.html?sidenavstate=11>304 Specs</A>
JT
jtn,
Thank you for the link.I actually went there already and could not get the file to open,so I was looking for other options for the specs.I am looking at a used 244E and didn't want to goto a dealer for the info,but I can if worse comes to worse.
/ Heavy equipment specs??? #4
I got it to open.
Yanmar engine 55 net hp 182 ft lbs
Two range Hystat 0-6.2 0-20 forward and reverse
lift capacity to full height 7250lb. Breakout 10,145 lb.
GP bucket 1 cu yd MP bucket .78 yd.
Operating weight 11,746 lb with GP bucket
Operating weight 12,205 lb with MP bucket
HTH, reply if you need more info.
Scott,
Thanks for the info,I really appreciate it.If you happen to have a spare second,do the specs happen to list the lift height to the bucket pins?If it does could you post it,it would be a great help.
/ Heavy equipment specs??? #6
10' 4" to pins
/ Heavy equipment specs??? #8
I was a little slow on the draw that time... /forums/images/graemlins/grin.gif
Hoeman & Scott,
Thank you both very much for the info,it is greatly appreciated,and will not be forgotten /forums/images/graemlins/grin.gif
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A59914)
2020 KENWORTH T680...
2009 Ford LCF Box Truck (A66285)
2009 Ford LCF Box...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
2011 Polaris RZR 900  (A62679)
2011 Polaris RZR...
2020 CATERPILLER 326 EXCAVATOR (A65053)
2020 CATERPILLER...
