Rear Blade Heavy duty rear blade
/ Heavy duty rear blade #1
Rowski
North Central Vermont, Jay Peak Area
2004 New Holland TN70DA with 32LC loader, 2000 New Holland 2120 with Curtis cab, 7309 loader
Who makes the most rugged rear blade (cost not really an issue)? Will be going on a 43hp 4wd tractor. I'm thinking 6' or 7'. Thanks again for the help.
/ Heavy duty rear blade #2
I don't know who makes the most rugged, but I can tell you that a Landpride Series 35 is pretty much impossible to tear up with that size tractor, or one anywhere close.
Mark
/ Heavy duty rear blade #3
I don't know who makes the toughest one either, but I'll bet you couldn't break a Monroe Tufline.
Bird
/ Heavy duty rear blade #4
/ Heavy duty rear blade #5
Rowski, I have a Hardee-Williams ABH-84. It has proven to be a very good blade. It is well constructed. I have had blades in the past that would get a lot of slop in them after some use. This blade has remained tight after much use. It has several different adjustments including being able to extend the blade out to the side. http://www.hardeew.com/products/landscape/hdrsb.html JerryG
/ Heavy duty rear blade #7
Like others, I can't really say which blade would be the most heavy duty when cost doesn't matter. I did note, however, that a six foot size is under possible consideration. I don't know the tire tread width of your 43 HP tractor, but I'll wager that it is probably about six feet or larger (mine is). The utility of a six foot blade mounted on such a tractor is rather limited because as soon as the blade is adjusted to an angle to move material off to the side, the effective width of the blade can decrease the point that you will be working an area smaller than the tread width. This is usually undesirable. I'd say go with a larger size.
/ Heavy duty rear blade #8
I bought an inexpensive ($650) 8 ft Cat II blade for up to 85 HP. It swivels 360 degrees and tilts in 2 positions each side. When set at any reasonable angle it grades about 6 ft wide. The blade weights about 600#. You would need to install Cat I pins in place of the cat II for your tractor. Look at the HP rating - it gives a pretty good indication of the ruggedness.
Next consideration is whether the 3 point on the tractor is suitable for an 8 ft blade as the blade may now be heavy enough but the tractor may not be. If you hang the tip of an 8 ft blade on a rock, you really need to be going slow and paying attention. I sure like a box blade better than a rear blade, but it won't grade snow or dig ditches.
/ Heavy duty rear blade #9
I just got thru researching the same thing and found a Landpride 35 series and Bushhog 70 series side by side. Only advantage to either one was the actual blade on the bushhog was a little better braced.
Hope this helps
Thanks for all the input. Bought a Woods HBL84 heavy duty 7'. Also bought (in the same purchase) a Woods LR107 rake (7') with dual casters. Again thanks for the help.
Rowski
/ Heavy duty rear blade #11
Re: Heavy duty rear blade: Rowski
Derek,
I noticed from the information in your profile that you have a Woods model HBL84 rear blade. I'm looking into the Woods RB700 or HBL84 and would be curious to know how much you like/dislike the HBL84. At 500+ lbs, has the weight given you any problems? I'm looking for a blade to use for snow removal, ditching, spreading soil, moving logs and cracking walnuts /w3tcompact/icons/wink.gif. Thanks for any info you can pass along.
Russ
UNVERFERTH H25 - 25' HEAD CART (A64277)
UNVERFERTH H25 -...
2013 ALLMAND MAXI LITE 8KW LIGHT TOWER (A65643)
2013 ALLMAND MAXI...
2014 CATERPILLAR 938K WHEEL LOADER (A64279)
2014 CATERPILLAR...
Grass Seed (A65640)
Grass Seed (A65640)
2000 Sterling Rollback L9500 Series Truck, VIN # 2FZNEWEB1YAG12895 (A65563)
2000 Sterling...
2007 International 7300 Digger Derrick Crane Truck, VIN # 1HTWBAAN77J422035 (A65563)
2007 International...
