Heating Oil Access
/ Heating Oil Access #1
mikesee
wilmington, de
BX2660, RTV 900, RTV 1140 CXP, B21, KX-018-3, KX 121-4
Just got back from driving to buy diesel, lugging 5 five gallon cans back and forth for my RTV and BX2660. I use wood and heating oil to heat my house. I have a solid 275 gallon tank of heating oil in my basement, easily accessable. I am looking for safe secure clean way gain access to this fuel source so I don't burn fuel to get fuel. Any recommendations on what type of pumping system I should look into? Just need about 4 gallons a day to run my equiptment. Am not looking to dodge any taxation issues
/ Heating Oil Access #2
If used off-road, no taxation issues apply. Some easily removed pump installed on the filler pipe would be easiest.
Thanks Mike, accessing the tank from the outside is a better Idea than messing with doing it indoors. Good idea
/ Heating Oil Access #4
I really don't like the smell of diesel in my house (funny how I liek it outside though). So I avoid doing any filling inside. My solution was to get a 55 gallon drum that the dealer fills when he fills my tank. It's on a stand with wheels so I can move it around the garage as needed and intot he corner when not. Much easier than putting a pump in the basement and running a hose outside. If I ever need to fill it when I have plenty of fuel in my 275 tank it's easy to put the drum in the back of my truck with the loader. With a 55 gallon drum you can save some money and get a hand pump.
2021 JOHN DEERE 6145R TRACTOR (A59823)
2021 JOHN DEERE...
2008 KENWORTH T300 FLATBED FUEL TRANSPORT TRUCK (A58214)
2008 KENWORTH T300...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2014 BRENNER TANK CRUDE TRAILER (A60736)
2014 BRENNER TANK...
2025 MMS MS36CJ (A60463)
2025 MMS MS36CJ...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
