Heat Pump
/ Heat Pump #1
retired007
New Holland 3930 Kobota Zd21 Mule 4010 New HollandTZ25DA
What brand do you have and are you satisfied? What brands have you had and did not like.
/ Heat Pump #2
Won't matter that I say this, but... brand does not matter, what matters is the company when it comes to HVAC.
I've worked in HVAC in various parts of the east coast, and what it all comes down to is the support network. What's "big" in one state may not be the same in other for various reasons, including marketing and distribution.
That said, not a fan of Nordyne in that they use micro channel with both indoor and outdoor equipment, AC AND heat pump, and you airflow and static pressure need to be dead on to ensure you don't have any future issues.
Any decent HVAC company will give you at least 3 different options as well as perhaps do a load calculation on your home to verify capacity.
/ Heat Pump #3
Most of it will be what your contractor uses. Typically contractors wont/can’t supply all brands. It depends on their wholesaler or account.
Most brands are decent. I’ve had York and Rheem. Both were fine.
/ Heat Pump #4
I generally prefer Goodman as they have a good warranty, are made in the USA, and have great parts availability. As a bonus they are typically inexpensive.
However, it is really all about a good installation, properly sized. Make sure to get a load calc.
The best brand poorly installed is worthless.
/ Heat Pump #5
The regular heat pumps are both Carrier. Really like them: very quiet. Previous ones were much noisier. The big one was a Trane.
Suspect any newer heat pumps will be quieter than older ones. Think they've learned how to make them to tighter specs, similar to what they've done on car and truck engines.
Like the new Carrier thermostats. Everything is altogether (incl. humidistats) and controllable.
Ductless one heat pump is Mitsubishi. It's, of course by far, the most quiet inside and out. Best thing about them is there's no heat coil backup needed. More efficient, too. Downside is the refrigerant lines running to all the users. If you put them in from new, these would be so easy to hide.
Ralph
/ Heat Pump
Have a Trane and have always had quick service. Have been without air for13 days and it is very hot and humid. Installer says they can't get parts. I like to be reasonable but patience's are wearing thin. I was just wondering if other folks had dealt with this kind of problems.
/ Heat Pump #7
Sorry I didn’t answer part of your question- I love the heat pump! It has electric backup. I was in an area where everyone tried to get on natural gas because electric is so expensive. But the PNW has about $0.10/kw electric and natural gas is limited. This system beats propane. I haven’t been through a major power outage but that would be a reason to use propane backup.
/ Heat Pump #8
I have a Heil Heat Pump with propane back up, Dual Fuel set up.. That way if I lose power I can run the blower on 120 VAC from a small generator and run on propane. It works quite well and I don't need 220 VAC to run the outside unit or heat strips. AC is a different story but I can go to the basement if I get hot.
/ Heat Pump #9
Good advice here........find a quality company. We've used Trane and Carrier in our buildings.....seem to work well.
/ Heat Pump #10
Don't know your location, but you might want to look into a VRF unit. Depending on where you live, you won't need back up heat.
If you go conventional HP, like has already been mentioned. I would not go with a Nordyne product
/ Heat Pump #11
Ken, I might of missed it, but who makes a single phase VRF unit and when say VRF unit, are you refering to simultaneously heating and cooling for each zone?
/ Heat Pump #12
Mitsubishi offers 3 lines for residential (single zone), each with a different up front cost, and each with different heating performances at various outdoor temps.
For multi zone, their standard 4 zone 3 ton multi zone will only give you around 24,000 BTU/h of heat at 17 degree outside air temp. Their high performance model will give you over 40,000 BTU/h of heat, but you'll need to run a branch box and the cost is substantially higher.
If you do not have supplimental heat, you need to ensure you know exactly what you're getting performance wise for heating capability and at what outdoor temp.
I'd put a single zone in my home if needed, but anything over 2 zones (2 indoor heads) for various reasons, I'd stick to a conventional ducted system if you already have the ductwork and it's just a retrofit job.
If you do put in a high quantity (over 3 indoor heads) multi zone mini split, highly suggest spending the money and put refrigeration ball valves on every liquid and suction line off the indoor head. If one head goes out, without ball valves in place, the whole system is down for repairs.
3 brands of mini splits (over 80 different names being sold in the US and none are made in the US). Go with a very cheap China brand, good expectation you won't be able to get a replacement past 5 years.
/ Heat Pump #13
It doesn't matter what brand. When it comes to heat pumps this is what I prefer:
1. Copeland scroll compressor multistage. I've had really good luck with those compressors.
2. Heat pumps with stainless steel condensate drain pans & body panels.
Last but not least, nowadays I will install multi-split system over standard system anywhere I have a choice.
/ Heat Pump #14
I've lived in Japan since 1981, and a few things that came to America surprise me:
1. karaoke (oh me, how did Americans get "carry" out of kara... kara, as in karate. Well, almost.)
2. Manga
3. Sushi
4. Mini split heat pumps!
Mini splits (as y'all boys call'em here) were invented in Japan and I've used about every brand they make, all with equal success. As long as it's Hecho en Nippon. Don't want ary Chinese made mess. I really like them, but as mentioned, no ducts are also a downside. No heat/air in baffroom, etc. as with ducts.
In America, I've used Goodman a short time, and Carrier since 1980 in house. First one was gas heat, not heat pump, but ac part lasted 23 years. Had new Puron Carrier installed in 2003 ($5,000!!) and the condensate coil has NEVER drained right. It has dripped condensate on floor almost constantly. I had to put rubber pan all under it to catch water! I found out that Carrier messed up for a few years when mine was made. Yep. Jerks messed up. So I have bad feeling toward Carrier now.
My hvac place uses mostly Trane, so that's probably what I'll get next time.
But I also need a total system on a house we are redoing from studs/rafters/crawl space out in Missouri. This is like a brand new house build. I plan to do spray foam insulation in whole house, so that will make a difference in size unit. Don't know what I'll use there, whatever local man recommends I reckon.
/ Heat Pump #15
Ralph
Correction: The ductless units are Fujitsu. A friend of mine has Mitsubishi, and I asked for them. Our HVAC people said they could get a better price from Fujitsu. Utterly quiet outside. Only way to tell if it's running is to look closely at the fan inside. Inside, the fan at full speed (it's variable as needed) can be heard but less noise than a quiet floor fan. These are the most efficient units of the 3.
Ralph
/ Heat Pump #16
I put in 2 Ductless Mini Split systems in my and my wife's shops 2 years ago. I went with the "Mr Cool" brand "DIY" mini splits. They come in 2 pieces with a pre-charged 25' linesets. Just install them and hook up the wiring and you are ready to go.
I installed a 1 ton unit for the wife's 800 sq ft shop and a 1.5 ton for my 100 sq ft and they are amazing.
Of course, the best part is both were delivered for $1,900 (total). The only other cost was some wiring.
/ Heat Pump #19
Wait until you need parts...
I've been down that road believe me.
/ Heat Pump #20
Actually, I just had a leak develop in the air handler side of the unit. They sent out a new air handler (including the line set pre-charged) under warranty and I was up and running in no time. Great people to deal with.
20 FOOT SHIPPING CONTAINER WITH CONTENTS (A68842)
20 FOOT SHIPPING...
Kaufman 47ft. Gooseneck Tri Axle Car Hauler Trailer (A66736)
Kaufman 47ft...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
x (A68191)
x (A68191)
213137 (A64276)
213137 (A64276)
2014 GULF STREAM TRAILMASTER (A65643)
2014 GULF STREAM...
