Heat Pump and power consumption
   / Heat Pump and power consumption #41
The other factor is the user. DO NOT set back the temp unless you will be gone for days. Constant temp setting is the best option. After a setback, the requirement for a rapid temp rise will cause most units to kick-in aux heat. Some modern thermostats that are programmed for a setback will slowly rise temperature and not trip the aux heat, but in general the savings from a setback are exaggerated.
If your outside temperatures are above 40 degF day and night, can you just turn off the elec reheats at the breaker?
   / Heat Pump and power consumption #42
I'm thinking after reading through this thread, that I ought have a HVAC technician come out and do a check up. I have forced air electric tied to a heat pump. I recently installed a Nest thermostat and I am unsure I have the setting correctly. I never really paid attention to when or if my heat pump came on in the cold weather for heating. I do recall it coming on for A/C cooling but thats because I am outside then I guess.
Been 10 years since we have lived here... never had a tech out yet. :ashamed: I guess that is a good thing.
   / Heat Pump and power consumption #43
If it is a heat pump it should be your primary heat source in the winter with the outdoor unit regularly coming on.
   / Heat Pump and power consumption #44
I guess I had better get a service tech out.
   / Heat Pump and power consumption #45
To a side note. Duke Energy sent me access to an online comparison of my energy usage versus average usage for my size of home in my area. My average consumption is over the average and they have suggestions on how to correct it. I know how to correct it. New windows and tighten up a 65 year old brick house built to 1953 standards.
I have found that as my wife and I age gracefully into senior citizen status it requires more heat to stay comfortable. And I will stay comfortable.
   / Heat Pump and power consumption #46
Heat pumps are sized based on your cooling needs not your heating needs so the AC runs long enough to de-humidify the air. On heat side of things they are 12,000 btu's per ton, so heating your home with a 3 ton unit is like heating with a 36,000 btu furnace. When we built I told the HVAC man to size it for heat.
   / Heat Pump and power consumption #47
Lots of difference heating a 1400 sq ft ranch vs a 2500 sq ft 2 story. Air has to be pushed a lot farther and a lot more variations in temp between floors. Plus our house was built in 1970. Newer construction is much more efficient. Although ours is all brick
There really isn't any difference between heating and cooling a 500 square foot home compared to a 5,000 square foot home.
Proper load on home by each room, proper duct design for each room. Now, heating and cooling loads can very greatly between two homes that are the exact same size.
North Carolina is now code that new homes must maintain a 2 degree difference between floor levels.
The reality is however that in general, larger multiple floor homes do cost more due to the layout and extra install material and size of equipment.
On a new install with ductwork, I've seen the same cost vary by as much as $10,000. Sometimes the there IS a reason for the price variances. The key is that the end user know what they are getting and what of their expectations can be met.
   / Heat Pump and power consumption #49
Heat pump air handlers that have more than one breaker incorporated with them have more than one stage of resistance heat, you can turn off the stage or stages that don't include the power to run the fan and controls. However, if temp is above 40, and no one is turning the thermostat up, the resistance heat would only be running when the heat pump is defrosting, and that doesn't take long.
   / Heat Pump and power consumption #50
I can shut my backup aux heat electric strips at the thermostat or the breaker. I actually have a 10KW heat strip and I turned 1/2 of them off. So only 5KW kick in when it is needed. I used to keep them turned off completely but my house is so efficient and my bills are relatively inexpensive for the size of our home.
2025 GIYI Single Cylinder Hydraulic Grapple Stump Bucket Skid Steer Attachment (A50322)
2025 GIYI Single...
2019 MACK GR64F TANDEM AXLE CEMENT MIXER TRUCK (A52577)
2019 MACK GR64F...
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
2803 (A50460)
2803 (A50460)
2012 Chevrolet Colorado Pickup Truck (A50323)
2012 Chevrolet...
2022 Iron Craft 10' 3pt. Rotary Mower (A50774)
2022 Iron Craft...
