Heat Pump and power consumption
   / Heat Pump and power consumption #1
KTurner
We just got an electric bill and the usage is the highest it's been in the 9 years we've been in this house. I need to figure out if something is malfunctioning or if this is a combination of the cold weather and my wife fiddling with the thermostat. Our heat pump is about 7 years old and replaced one that was about 25 years old. The heating degree days isn't very different from the same time last year, about 10% higher. This bill has us using 103kwh/day while the corresponding bill from a year ago was 70kwh/day, an increase of almost 50%. Dec 2017 bill is roughly the same as Dec 2016 bill, with 61kwh/day and 58kwh/day, so this appears to be a sudden change. I don't doubt these numbers as they are actual measurements and not estimates. I realize that defrost cycles and big gaps (>2F) in current indoor temp versus thermostat setting will both cause aux heat strips to come on. I think we're pretty good at avoiding big gaps between current and desired temp. Defrost cycles... not sure how to track or estimate this. When the outdoor temp drops, obviously the heat pump has to use more power to keep the house at the same temp. Would this be the same amount of power for a longer time or does the amount of current go up also (ignoring the aux heat and defrost cycles)?
I took a couple readings from the meter. For a 13 hour period overnight we used 82kwh (>6kw/h ave). Looking at how long it took the meter wheel to make a revolution, it was about 1kw/h when the heat pump was off (and everyone awake, lights, tv, coffee pot, etc on) and 3kw/h when it was running - implying heat pump was using ~2kw/h. If the heat pump uses the same power but runs longer, then something else is contributing >3kw/h on average that entire 13 hour period - but wasn't when I took the measurements.
Keith
   / Heat Pump and power consumption #2
A lot will depend on how cold it was and for how long. I just recently experienced my highest heating bill ever, and our new heat pump, with electric back up is only 4 years old, but we just also had the coldest start to January in the last 100 years and did not break 32 degrees in 15 days. When you look at the temperature they put on electric bills, they are pretty deceiving as they are an average for a months time. The thing to remember is a heat pump is only good at reclaiming heat to about 20ish degrees if I remember, after that it runs constantly and requires the auxiliary heat strips to make up the difference. I kept an eye on my thermostat and my aux heat was coming on fairly regularly with a constant unchanged temperature setting. Now that temps have evened out again and we are out of the cold snap, the heat pump has begun to turn off and cycle normally again.
Reason #24235 why I can not wait to get my chimney relined and wood stove fired back up.
   / Heat Pump and power consumption #3
I have used a heat pump for the last 18 years, backed by a 3-stage gas furnace. What I found is that keeping the house constant temp and not using set-back except for very long duration periods (weekends away, etc.) and not short 4 to 6 hour periods is the most economical. We have found that the heat pump 'maintains' temps but isn't great at recovery from setback. Also, refrain from bumping the temp up because you feel 'chilled', put on a sweater or in our case a small space heater when we're watching TV, it's more economical to run it than keeping an unused large space at comfort temp. We also push our system to run down to about 25* before switch-over to gas occurs, as running the heat pump to maintain temp is less costly than on gas.
If it's extremely cold you may be running on backup electric heat more than you realized, like overnight when the temps plummet and costing much more than you realize, and if that's the case and the outside temps never achieve heat pump operation level you may benefit from using setback at night to conserve the use of electric heat backup power. We've actually found that when constant sub-25* temps prevail, we can lower the thermostat a couple degrees because the 'feel' of the gas backup heat is warmer than the 'feel' of the heat pump heat, haven't found an automatic way to do that though.
Managing energy we've found consistency helps, avoid the temptation to increase thermostat when not active (like watching TV) and using alternatives such as snuggle blankets and quilts, or small personal radiant space heaters.
Just some of our experiences, hope it helps.
   / Heat Pump and power consumption #4
I have a 4 year old Heil Heat Pump with propane back up, no heat strips. Not sure how efficient a heat pump is below 30 degrees F. I have the lock out set on mine at 30 degrees so it automatically switches to propane under 30 degrees. A lot cheaper to burn $2.00 a gallon propane than have that outside unit struggling. We have had some long cold stretches here in Eastern Kansas this year but hopefully we are on a warming trend. We also use a space heater in the living room at night and one to take the chill off the bedroom before bed. Typically the thermostat is on 68 day and night in the winter.
   / Heat Pump and power consumption #5
Below 30 degrees and you're essentially heating with a toaster element. The actual heat pump is useless; that's why some have the lockout to switch. If you are having a truly long cold spell, switch the system to 'Emergency' and that should lockout the heat pump compressor from running (reducing your overall electric use) and only running the resistance elements and the fan.
   / Heat Pump and power consumption #6
these comments need to be watched, some heat pumps now are efficient down to -5F, they most certainly are still putting out heat at 30F
   / Heat Pump and power consumption #7
Probably so, but at what cost? The Heat Pump may run for 20 minutes vs the furnace may run 5 minutes on propane for the same result.
   / Heat Pump and power consumption #8
Has the cost per kWh increased from previous years?
   / Heat Pump and power consumption #9
Depending on the heat pump, you're comment is far from spot on.
Currently I'm watching a church up in the mountains of Tennessee use 4 heat pumps with 4 gas furnace for back up heat.
At 10 degrees outside air temp, the furnaces won't even come on, and the church is maintaining 67 degrees inside unoccupied. The system doesn't have strip heaters.
KTuner, if you haven't changed anything with the system per wiring (new t-stat), my money is on the wife playing with the t-stat. As Frugalanger mentioned, try to keep the temps even without a huge lag between temps if you're using a programable t-stat. Programable t-stats are "supposed" to save you money, but if you program it to heat and the system has to make up more than 3 degrees, you're generally going to burn your heat strips. This is one advantage where a duel fuel system helps. Use the gas furnace to make up the lag difference then have the heat pump maintain. The last thing you want to do is have the t-stat on 69, then to try and save money, set it to 64 while you're away, only to turn it back to 69 when you return.
Years ago I had a spike in my electric usage by a good bit. Finally narrowed it down to the well pump, which was a pretty penny to replace.
   / Heat Pump and power consumption #10
The reason for your high elec. usage is your aux heat strips are being energized /used. The colder it gets the more your hp will go into defrost.
Sounds like a good reason to switch to a VRF unit, mini split.
I have one mini split @10 deg. my mini split was putting out 114 deg air. No elect. heat strips needed !
I'm going to replace my other older hp when the weather permits
   / Heat Pump and power consumption #11
alot of variable to even remotely accurately answer that question
   / Heat Pump and power consumption #12
For me anyway, the propane backup makes sense during power outages. I can fire up my portable generator and run just the inside unit on 120v and switch to emergency heat and just run on propane. You have to have a really large generator to run the heat pump.
   / Heat Pump and power consumption #13
If all environmental things are equal and the heat pump is now running longer my first thought is that it it’s low on refrigerant. You will need to have it tested for leaks and topped off to bring the efficiency back.
   / Heat Pump and power consumption #14
That would be the "Ductless Mini split" system(s). :thumbsup:
Very different from the typical central "ducted" heat pump commonly installed for the past 20+ years.
   / Heat Pump and power consumption #15
When it's "full on" winter up here, I heat with a wood boiler & radiant heat. BUT we just put a small addition on and put a "2 head" mini split system in, primarily for A/C. Just for kicks the other day, (it was about 8*) I switched one unit on, it was throwing out hot air!
I'm not sure I would rely as a h/p in our climate without a backup, but that's just a guess on my part. Anywhere south of the Mason Dixon line I think that they are the way to go!
   / Heat Pump and power consumption #16
The OP doesn't list his super-secret location. ???
I track my usage by reading the meter everyday at the same time (when I feed my outside cats) and log it.
I take my bill and divide kw used by total of bill. I average $.12 a kw. I can calculate daily cost. It's a hobby.
My usage is up and down, just like the weather!
   / Heat Pump and power consumption #17
Installed a new Trane heat pump in Dec. 2016. Thermostat is set to 72 and the heat pump can maintain this temp without aux. heat strips kicking in down to around 15. 2 1/2 ton system and 1400 sq. foot house. Used to lockout old heat pump compressor at 10 degrees. Has been down to 0 recently and still left compressor energized as was still producing usable heat. Read recently that heat pumps produced in last few years have made lots of advancement in extracting warm air from frigid air that was not possible several years ago.
I do, or did, the same for a good while. I was able to pull up my somewhat out of date spreadsheet and do some comparisons to past winters, including heating degree days and prior consumption. If I hadn't slacked off on reading the meter, I would have known exactly when this issue started. Instead, I got a shock from the bill we received yesterday. Which had a meter reading date of 8 days ago. Add a couple more days to get the issue identified/fixed and it looks like the next bill is going to be pretty high too.
After watching things over the past ~26 hours, I think there's something wonky with the defrost cycle on the heat pump. My meter shows 172 kwh used over the past 26.6 hours. The temp during this time ranged from 37F to 24F. That temp range is not unusual for us, but that power consumption is way high for us - like 2x-3x compared to prior Januaries. I checked the meter 9 times today and didn't see anything that seemed high except when a defrost cycle was going. At that time, it was pulling about 20kw. I watched one defrost cycle and it took about five minutes. I think I heard it go into defrost 3 times in about an hour. The heat strips are definitely coming on during the defrost, but I don't think they're coming on to assist the heat pump in maintaining temp in the house.
I'll call someone in the morning to come take a look at it.
   / Heat Pump and power consumption #20
Did someone do a load of clothes in the dryer?? Or Bake something?
Have to cover all possibilities.
2009 CATERPILLAR AP1000D ASPHALT PAVER (A60429)
2009 CATERPILLAR...
KOBELCO SK170-9 ACERA MARK 9 EXCAVATOR (A60429)
KOBELCO SK170-9...
2018 JOHN DEERE 844K-III AG HANDLER WHEEL LOADER (A60429)
2018 JOHN DEERE...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2018 CATERPILLAR 259D SKID STEER (A60429)
2018 CATERPILLAR...
