Headlight Grill help needed
/ Headlight Grill help needed #21
My Mitsubishi front grill is molded plastic.
Simply not available but I did have all the bits and pieces.
I used a hot glue gun and scraps of PVC as backer and simply hot glued the grill back together. So far (like 5-6 years) it has held up very well.
Many other plastic parts have been fixed with this method including my trailer fenders. Try it.
Roughing the parts helps as well as fusing the broken parts.
WIRE MESH
If you go to the local lumber supply they will have galvanized stucco mesh in 2' X 8' sections.
It will look good and it is fine for the job. Cost should be under $10.00
/ Headlight Grill help needed #22
I would use epoxy type glue. The two part kind or JB weld and use something, maybe a strip of metal as a backer and lay it down in there and goop the glue to it.
/ Headlight Grill help needed #23
WIRE MESH
I repaired the ABS plastic grey water tank on our camper by welding it. Used scraps of the ABS pipe fittings for stock.
/ Headlight Grill help needed #24
I found a pair of bolt on rectangular running lights . About the same size as headlights on my 1700. Silicon-ed them in from the back and wired them up. Clear Lens Halogen Lights. From the front looks like original lens. Halogen bulbs. Lights up the whole field.
/ Headlight Grill help needed #25
Mine in my YM2001 is disintegrated and gone also. I want to make something to go in its place but I do not want to use wood. I have a plan to use cutting board material of appropriate size, cut, shape and mount a set of these.
Amazon.com: NiteBruiser ® 2 pcs 18W 3x3 Dually Flush Mount CREE LED Light Lamps Dually D2 Off Road 4x4 4wd Jeep Truck F150 Tacoma Bumper 3" Flood: Automotive
I really like to change out to led's whenever possible. I also plan on getting some of these as a rear light, as mine is missing from the tractor.
Amazon.com: TMS® 2 x 18W 1260LM CREE Spot Led Work Light Bar For Off-road SUV Boat 4x4 Jeep Lamp: Automotive
Case-IH 165 Puma (A57148)
Case-IH 165 Puma...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
Giyi GY-TB47 Telescopic Forklift Boom (A60463)
Giyi GY-TB47...
Sdlanch SDLGM1220F (A60463)
Sdlanch SDLGM1220F...
Sdlanch SDLGC80 (A60463)
Sdlanch SDLGC80...
2011 DOOSAN G40 GENERATOR (A60736)
2011 DOOSAN G40...
