headlamp problem
/ headlamp problem #1
Boogle1
Jersey Shore,Pa.
CK 35 Kioti
I would like to know if both low and high beam relays on my CK35 kioti could be blown? How do you test the relays with a vom? We have voltage to the relay plugs of both. We have spent a lot of time troubleshooting this problem. Maybe a wiring schematic would be helpful. Any response would be greatly appreciated. I just now became a new member and look forward to chatting with a lot of other tractor owners. Thank you, Boogle.
/ headlamp problem #2
/ headlamp problem #3
Here's what I have for the relay location. You say you have voltage to the relays. Is this voltage the 12 volt supply to go to the lights for when the relay closes or the 12 volts from the headlight switch to energize/close the relay? I'll check my manual for a wiring diagram.
/ headlamp problem #4
Did you check headlight fuse? Ground wire to the headlamps?
2009 CHEVROLET 3500HD 4x4 PICKUP TRUCK (A59912)
2009 CHEVROLET...
Danuser SM40 Skid Steer Pile Hammer (A65640)
Danuser SM40 Skid...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
Woods RB850 3Pt Blade (A66408)
Woods RB850 3Pt...
Rear Axle For Case IH 2388 Combine (A65640)
Rear Axle For Case...
Stout Buckets HD72-3 Brush Grapple Skid Steer Bucket (A65640)
Stout Buckets...
