head lights went out
/ head lights went out #1
tstex
Platinum Member
Alleyton, Texas; Houston, TX
1997 Kubota M5400S
Hello to all,
For the first time ever, my headlights on my 1997 M5400S did not work. Not sure the last time I used my tractor at night, but they would not come on in either hi or low mode. The dash kind of lit up some, but not as strong as what I remembered. The flashing rear lights work fine.
I did not have time to troubleshoot anything bc I have to leave to go back home. The battery is new.
What would be a good order of steps to determine what is wrong? I would imagine seeing of mice chewed something, if any plugs came undone. Is there a fuse for the headlights? My Op's Manual is at the ranch and I forgot to bring it hm w me.
Thank you in-advance for your help,
tstex
/ head lights went out #2
Basically check fuses and check switch for correct contact closure when operated (volt meter or test light)... If both good, start chasing wiring, could be as simple that a "connection" became disconnected...
/ head lights went out #3
The headlights probably work off of relays. Good place to start After checking fuses.
Thank you very much DL & grs, appreciate it. I also keep my tractor covered inside a shed at all times when I am not using it...On my model, where typically is the fuse box located? I do not believe I have ever replaced a fuse...Are the relays close to fuse box? Thanks again
/ head lights went out #5
Not sure about a '97 but the later models have the fuses under the steering wheel on the left side.
Recently lost lights in my 5800 but was the results of mice finding the wires underneath the cowling behind the steering wheel so was only able to diagnose it with a multimeter/continuity.
/ head lights went out #6
Carefully inspect headlight wiring. You may have had rodents snacking on the insulation.
I suspect mice is the issue, but will do as you guys suggest. I am hoping for a fuse. I will also have access to my Op's manual so I can go thru that process of troubleshooting.
Did a search on the matter and listed below...pretty much what you guys have stated. I am going back either tomorrow or Wed/Thur, so I will troubleshoot and post back...thanks again to all
  1. Neither of the headlights work.
    • The cause: Burned out bulbs, or an issue with power or ground.
    • The fix: Check for power and ground, and fix if necessary. Otherwise, replace the bulbs.
    • Bulbs usually don’t burn out together, but it’s still important to rule that out by checking for power. Most total headlight failures are caused by a bad component like a fuse, relay, or module. Wiring problems can also cause both headlights to stop working.
/ head lights went out #8
Turn you lights on and check for voltage from
the head lights back (the wires) should be an
easy find and fix. Attached the black probe to
ground and probe with the red wire
willy
Ok, well whomever guessed mice, that’s it..sorry little basxxxds!!
Is it possible to re use these white plastic clips? If so, what’s the trick to getting old wires out and new in? If not, does anyone know of a place to acquire them?
thank you very much in advance!
/ head lights went out #11
The is usually a prong on side of terminal that locks terminal in plastic shell, inserting a thin straight metal object between terminal and shell should release terminal, and push out from wire side... You may be able to open up crimps to replace wires or if crimps do not hold , solder connection...
UNUSED WOLVERINE SB78-78" ROCK BKT (A64281)
UNUSED WOLVERINE...
(2) FORESTRY TIRES ONLY (A64276)
(2) FORESTRY TIRES...
2022 John Deere 616R Sprayer (A63111)
2022 John Deere...
UNUSED KUBOTA 48" PIN ON BUCKET (A64280)
UNUSED KUBOTA 48"...
2009 Jaguar XF Sedan (A61574)
2009 Jaguar XF...
2019 John Deere 9470RX Tractor (A63111)
2019 John Deere...
