Head Broke Off Bolt...Please Help!!
/ Head Broke Off Bolt...Please Help!! #1
Prodirt6000
Bronze Member
Hi Everyone,
I have a bolt probably around 3/8 inch I think that the head broke off of it in the casting. I have this tool that once you drill it out and heat up the bolt, you can turn it counterclockwise and it will turn the bolt out.
My problem is, I have a drill bit broke off in the bolt. It is too far in to grab and pull out, and I've tried a magnet too, and tryed turning it with a little screw. Nothing. Oh and I tryed using a bigger drill bit too which was probably a mistake. That didnt work
So how to I fix this? It seems to me that a different drill bit will not drill out another drill bit thats stuck inside there. Any ideas?
/ Head Broke Off Bolt...Please Help!! #2
If it is flush or slightly raised off the casting then weld a nut onto it...if you have a welder. The drill bit is to hard to drill, using another bit will probably lead to that breaking also.
Its flush. I have tryed welding a nut to it on another time this has happened but I could never get good enough penetration seemed like because the nut would always twist off. It was a 220V welder too. Maybe I didnt put enough heat on just because I was afraid I would weld to the other metal. Actually, the metal that the bolt is in might be cast iron. I'm not 100% sure though.
/ Head Broke Off Bolt...Please Help!! #4
Wow! You sure didn't make thing easy on yourself! The most sucessful practice that I've seen is Center-punching the bolt, then buying a counter rotating drill bit ie, cuts counter-clockwise. After drilling, which will some time bring the stud out, you then use an E-Z out (that's probably what you're refering to)and back out the broken piece after liberal amounts of PB Blaster, and maybe some heat. Once you've broken a hardened steel drill bit in the hole, you've got bigger problems. You' got to try to get that broken drill piece out! Any chance of backing it out with a a pair of snap ring pliers stuck into the 'drill-flutes' ? Any access from the back side? Or is this a stud hole install? ~Scotty
Haha yeah Scott I made a bit mess up with that broken bolt. I usually have good luck with the EZ out tool but not when I have a broken drill bit inside. I dont know if you caught it what I said earlier, but for some stupid reason I tryed drilling the hole out with a bigger drill bit. This made a burr I guess you would call it over the smaller drill bit. So now, I think I'm done for.
Oh and there is no access to the other side. My boss was wondering if I could torch out the old bolt. But ooof, I'm not sure if thats such a good idea.
/ Head Broke Off Bolt...Please Help!! #6
Turn your welder up some more and bury the rod in to the stud through the nut. I use 7018 rod. 3/32 would be a good size. I think 6011 is too brittle and 6013 not strong enough. The weld will not stick to the cast very well so don't let that scare you. Let it cool till the weld chills but don't let it cool off to the touch.
Did the original bolt break off or twist off while being removed. If you twisted it off you may not get it out. Can the casting be removed and taken to a machine shop?
Dan
Dan
Ok I might give that a shot in the morning. I'll try the 7018. Last time I used a MIG welder and had no luck, so I will try the stick like you said. Well, it looked like it was twisted off if I'm understanding you right. Taking it off and bringing it to a machine shop is our last possible thing we want to do...The casting is part of a piece under a 6 row corn head and it doesnt look like any simple task to take it off. It's almost like it is it part of the framing of it.
/ Head Broke Off Bolt...Please Help!! #8
1st If it broke while you were turning it out most likly bite fast it is highly unlikly it will come out uasaly drill and tap new threads 2nd If it was broken before atemping to remove you may indeed be in luck. Welding a nut down through hole in nut has worked many of time for me when easy outs have not. also since you have broken a bit off in the hole have done this to remove broken bit,put your safty glasses on,since a bit is HARD I have found if I take a good punch and decent size hammer I sometimes can shatter the broken bit in the hole use magnet to remove pc's and retry easyout or drill. good luck. after 35 yr's experience, some time's there just is not an easy way out
/ Head Broke Off Bolt...Please Help!! #9
Hi Everyone,
Post a pic if you can that would help offer the best advice.
Oh Red thats a great idea about the punch. I'm definately going to give that a try first thing tomorrow morning before I try anything else. If I can get away with not trying the welding trick that will be better for me.
Now I know the hole is drilled completely through the bolt, so if I drive that broken bit up into the origonal cast, will it do any damage?
/ Head Broke Off Bolt...Please Help!! #11
Probably what happened is that as the drill bit broke through the end of the bolt it grabbed hard and the torque snapped the bit. That's bad news for two reasons, first of all the bit is going to be a b**** to back out, secondly if you hammer too hard on it you may crack or break the casing behind.
My first question is, how critical is that one bolt to the operation of the corn head? If nothing is compromised or leaking, leave it alone until the whole thing has to come apart.
You may be able to take a Dremel with a small stone and grind away enough of the bit to get the easy-out in there, but they've been known to break off too. Don't ask me how I know this..:eek:
If it's in a location that will stand heat, heating the drill bit cherry red with a torch will take the temper out of it, maybe enough to drill it, but that's a tough job even in a drill press.
If it were me, I'd try sticking a welding rod to it, like the guys said the weld won't stick to cast well. A MIG will work too, if you can weld something to the end of the drill bit or even better to the bolt shank it MAY back out. The drill bit will for sure if what you weld to it will stand the torque to break it loose.
Only other solution is a machine shop with EDM capability to burn the bit and bolt out. Once the bit is out, if your first hole is well centered you can slowly increase drill size until you can pick the threads out or run a bottom tap in the hole.
Good luck,
Chilly
/ Head Broke Off Bolt...Please Help!! #12
first; if you use a punch on drill bit; wear safety glasses and protect bare skin as shapnel can come off that bit as it breaks. If you get it out; invest in left handed drill bits and use them first as as they bite, they will back out bolt; hopefully. If you use an easy out and it breaks; you are right back in situation you are in now.
Chilly thanks for all the advise.
I thought the punch idea was a good idea but I do worry about damaging the material behind it.
The bolt is one of the two bolts for one of the scraper plates under the corn head. That plate needs to be there...I could try making something else to hold that plate on, but would really rather have the bolt out and new one in.
Dave I actually did break an EZ out in the hole. I failed to mention that earlier only because I did have a drill bit that drilled right through it. I was very surprised. If that never happened, I would have had to go back to using a small drill bit to make a new pilot hole and I wouldnt be in this situation.
/ Head Broke Off Bolt...Please Help!! #15
I have backed bolts out by using a small punch to turn the bolt as I hammered. You need to hit it tangentially on the face.
If you can get the broken drill bit out, you can enlarge the hole until the bolt is just a thin piece, then peel it out with a small punch.
/ Head Broke Off Bolt...Please Help!! #16
Is the bolt placement critical ? Sometimes when you get yourself in a hole like that (pun intended :eek:) you just gotta grin and bear it and drill a new hole off to the side. If bolt placement is critical- think twice about using the welding with 7018 as the backup plan. If you use a punch to try to shatter the drill bit, you might find yourself with nothing to weld onto. plan ahead on whats "ifs" first before yiou start swinging that hammer. Don't ask em how I know- :(:eek:
/ Head Broke Off Bolt...Please Help!! #17
I think we are missing some of the story,You mention that you did break an easy out off,so now I have to think that bolt is fast, not just with the head broke off. Am I right in this thinking?
/ Head Broke Off Bolt...Please Help!! #18
Exactly... a center punch will sometimes turn the old bolt out, and a cape chisel (rounded tip) works well for getting the thin shell of the bolt out, it'll actually collapse it inward on itself with a few taps once you have it drilled thin enough.
I've not personally tried the welder trick, but I think if you can get an arc started,then deliberately stick the rod and turn the welder off, you might get enough bite to turn the drill bit out. Or maybe clamp a set of vise-grips on the rod and give it a smack with a hammer, use it like a slide hammer. Once the bit is out 90% of your problems are over. Any body else have any thoughts on this?
Chilly
/ Head Broke Off Bolt...Please Help!! #19
Before you do anything, try heating it and touching it with a candle to get molten wax to wick down the threads of the bolt. This makes the bolt a lot easier to turn...
Yeah I guess the reason why I didnt mention the EZ out was because I could easily drill through it. The bit broke off inside of it after going completely through it. I should have mentioned that though.
And the bolt hole is part of a framing piece on the bottom side of a 6 row corn head. This particular bolt holds one of the scraper plates on.
UNUSED RAYTREE RMT48-48" HYD TRENCHER (A62131)
UNUSED RAYTREE...
New/Unused AGT Quick Attach Auger with Three Bits (A61166)
New/Unused AGT...
2006 Ford Ranger Pickup Truck (A61568)
2006 Ford Ranger...
2017 Dodge Grand Caravan Van (A61569)
2017 Dodge Grand...
2019 CATERPILLAR TL642D TELESCPOPIC FORKLIFT (A62129)
2019 CATERPILLAR...
2017 JEEP PATRIOT (A62130)
2017 JEEP PATRIOT...
