Hazardous Location Receptacles
/ Hazardous Location Receptacles #1
kevincook
Platinum Member
k
This isn't really related but I'm sure someone here can probably help me out. I need some 480V 30A Hazardous Location receptacles at work and I need them fast. Does anyone know of an electrical supply company that actually stocks these items. I need 4 that are single phase and 1 that is three phase. (Class 1- Division 2 to be precise)
Thanks,
Kevin
/ Hazardous Location Receptacles #2
You might try Graybar. They have branchs all over and can probably search inventory.
No Luck with either of those sources.
Thanks, keep the ideas coming.
Kevin
/ Hazardous Location Receptacles #6
You need to find a industrial supplyer that sells Hubbel. 480V single phase might be tough to come by. We use a lot of 480v 3 phase twist explosion proof plugs at work in 2GII and 2FII areas.
Dan
/ Hazardous Location Receptacles #7
I would wire all them 480v 3 phase so they interchange one stock if you have spares even if load is single phase.
When I worked in a printing plant with alot of explosion proof areas we could get the Appleton over night in the ces cesd series via our local distributor but as you they weren't cheap
tom
/ Hazardous Location Receptacles #8
I have run into problems like this before and have called MFG Hubbell,Woods ,etc and they have looked at there sales and told me who stocks that item.
kenstrac,
Good idea. I called Crouse-Hinds directly and they where able to tell me what they had in stock in their warehouse. The part numbers that I was looking for had a long lead time but we were able to identify other parts that would work and are in stock.
Thanks,
Kevin
2011 UD Thermoplastic Truck (A64194)
2011 UD...
RYOBI GRINDER ON STAND (A67714)
RYOBI GRINDER ON...
8ft Fork Extensions (A66734)
8ft Fork...
2017 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A66736)
2017 Toyota Tacoma...
2012 ATLAS COPCO  AIR COMPRESSOR XAS 375 (INOPERABLE) (A68842)
2012 ATLAS COPCO...
2013 MACK CHU613 WINCH TRUCK (A67714)
2013 MACK CHU613...
