Haying small fields with a small tractor
   / Haying small fields with a small tractor #41
I ran a NH 479 mower, NH55 rake and a JD 14T baler with a 22 hp Yanmar. It didn't even have live power. Let the clutch in and we're balin' No problem. No triple rake windrows, but never a concern, didn't even touch the governor. Hitch weight only a concern on the mower, so that's why somebody invented front weights. The 14T's were offered with a 16HP Wisconsin motor on the plunger case. Why is everyone such an expert on something they've never tried or done ? I now have a 35 hp Deere and it even carries a full load on a NH1012 Stack wagon. Single bale unload makes it all smooth.
   / Haying small fields with a small tractor #42
My wife and I have a few neighbors that are willing to let us hay their fields for free, and we would love to save the money and do it ourselves. The fields are about 5 acres. Would my 24hp 4x4 New Holland be up for the challenge, or should we wait a few years till we can afford a bigger tractor? I found a few good deals on small bailers, and would love to jump on one. I know it would be ideal to have about 35-40hp, but I figured it's worth asking.
Regards,
you didn't mention your own hay needs, if so sorry i missed it. what are your needs & how many bales? what are you buying now in today's market? jumping into the hay business can get pricey real fast. plus the uncertain climate, etc... also calculate how many yrs the "savings" from cutting your own hay will pay off the hay equip investment
if your needs are modest, imho keep buying your hay without encumbering yourself w/hay equip costs. good luick
   / Haying small fields with a small tractor #43
When? How long ago?
I am new to this game. So you're saying dealers/the industry is telling people we have to upsize when that's not really true? (My farm is hilly, so I *do* need a weightier machine).
   / Haying small fields with a small tractor #44
Regards,
Chris
Chris,
My YM2610 31Hp Engine, 26Hp PTO can SQ bale just fine. It's about the same like the JD1025R Sub-Compact,
Kubota 25Hp can do it too.
With a Ford 1000 Series Shibarua sub compact 20Hp.
   / Haying small fields with a small tractor #45
A gasser 22Hp Ford 8N 2WD compact tractor does it all.
   / Haying small fields with a small tractor #46
Regards,
Chris
A compact NH SQ baling just fine.
   / Haying small fields with a small tractor #47
When? How long ago?
Couple of things: You probably won't be buying the newest and latest equipment. So, sickle mower (1-armed bandit), bar rake used, and an old auction candidate baler, no kicker or thrower and no wagons behind. My mower is a haybine (Hay + combine). Not only does it cut the hay but it 'conditions' it by passing it through a pair of crusher rolls. It has a reel out front to comb the approaching hay uniformly into the cutter. It then also has the ability to windrow the hay, good for several reasons: The ground will dry in each side of the windrow, which then can be side raked and flipped to get faster drying time. If you have GREAT weather, you can bale this windrow without the need to rake it. This mower needs a hydraulic supply, though, for header lift and the tongue swing. Tongue swing is not just for getting thru 10' gates, it allows you to differentially alter the cutting path to avoid fence posts, stones, whatever. The header lift is mandatory not just for turning around but to have the cutter self clean if it's picked up dirt or clumps. Raking, well its bar or wheel, or turnstyle/spinner. I have a bar rake and tow it on a dolly, I can rake with my golf cart. I also have a Kuhn tedder/rake combo. Throw a lever and adjust the wheels I can rake or fluff it. PITA to convert for several reasons, so I use it to fluff and the bar rake to windrow.
Baler is from the 50's JD 14T, a very popular baler these days for very small operators. Easy to fix, parts available because the common replaceables work on the new small square balers. Plastic twine works for me. The only issue I had was related to the driveline hookup. The short shaft from the braced driveshaft to the tractor MUST be centered over the hitch pin. This is because when you turn a sharp corner, the U-joints must be kept in phase. If the hitch pin is not in the center, the U-joint angles will be unequal and this will shudder & shake the crap out of the machine. I had to add a hole in my drawbar to get this to work.
Fact is, I'm working with a gal (who is on this forum), to get a NH bar rake, NH mower(s) (a 9-1/2' NH1465 and a 7' NH472) and a JD baler going right now. She has horses and dreams about providing her own horse food supply. She has a JD 4300 (30horse?) and it handles all the equipment just fine. Rear tires are loaded. Hitch is tight so no bucking. And she has 5 acres to do, just like yourself.
Now, the newer hay making machines are for real hay farms. thousands of bales. Takes time, maybe air conditioning, 3 or more hydraulic circuits, high weight for traction, big brakes, highway speeds, disc cutters and discbines, and all this takes much more power. Even big radiators. And these machines have many other heavy tasks. Snow plowing a driveway isn't one of them. Therefore, dealers go for the conservative HP estimates because you also get the weight and the features of a 65 hp tractor. They even look better IMHO. No teeny weeny tires, self leveling loader, battleship cab, lottsa levers, stereo, refrigerator, barbecue, keggerator, etc...
BTW: I have videos of my mowing and baling with my Deere in 2nd range. I could go faster but the fields are too bumpy.
   / Haying small fields with a small tractor #48
I'd add that either the best or the worst times of your marriage can come true with this. Either she'll be driving the tractor, YOU will be stacking the crunchy bales, and stashing them up in the loft and the dirtiest you have ever been. Or maybe the other way around. But you driving when baling ain't gunna work. And who's picking them up onto a cart, or a wagon, or the roof of your car ? If she's in the mow staking bales off the elevator, well, sweaty is sexy !
   / Haying small fields with a small tractor #49
Thank you. You have a lot of equipment knowledge... Looking forward to continuing to learn here.
   / Haying small fields with a small tractor #50
She's preggers and getting pretty far along. Right now, farm chores are "all me". :ROFLMAO:
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
2013 Chevrolet Express 3500 Passenger Van (A55973)
2013 Chevrolet...
2005 DODGE RAM 1500 (A58214)
2005 DODGE RAM...
2019 Ford Escape SUV (A56859)
2019 Ford Escape...
2016 Ram 5500 Chassis 4x4 ETI ETC37IH 37ft Bucket Truck (A56858)
2016 Ram 5500...
1999 International 9200 Day Cab Truck, VIN # 2HSFMAHR0XC036739 (A57453)
1999 International...
