Hay Storage
   / Hay Storage
I ended up going with a tarp. Some pictures of the stack before and after it was tarped.
The first picture is of how much hay I was loosing by storing it outside unprotected. You can see the size difference in the bales. The old bales are 1 year old. Baled last June.
   / Hay Storage #42
Looks good. Why didn't you stack the bales on gravel or pallets? Just curious.
   / Hay Storage #43
A major hay producer down the road from me just built a 150'X65'X18' barn. (side walls and roof nothing else) He said he was losing to much due to being stored outside under tarps. I assume he figured it was cost effective to build. Would you not benefit the same way? He sells 100% percent of what he grows, so bad hay does hit him hard in the pocket book.
Do you use your hay or sell it? Just curious.
x
   / Hay Storage #44
10,000 square feet sounds perfect!
   / Hay Storage
x
Oh I'd benefit but a hay barn isn't in the budget yet. I'm looking to grow, if so, I do I may end up moving my hay storage area. So I'm not ready to commit to the expense of the permanent structure. Although a 30x50 in that same spot wouldn't be bad.
I feed 95% of my hay. I sell very little.
   / Hay Storage #46
Plus the height. He can drive his bale wagon in and unload. It's a great set up. His family has been farming here for over 100 years and he just built the barn so think of the wasted hay over the years.
   / Hay Storage #47
OK, best of luck to you. One way or the other these things usually work out.
402 (A52706)
402 (A52706)
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
JOHN DEERE 4760 TRACTOR (A52708)
JOHN DEERE 4760...
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
CRAFTSMAN TABLE SAW (A54757)
CRAFTSMAN TABLE...
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
