Hay Storage
/ Hay Storage
I ended up going with a tarp. Some pictures of the stack before and after it was tarped.
The first picture is of how much hay I was loosing by storing it outside unprotected. You can see the size difference in the bales. The old bales are 1 year old. Baled last June.
/ Hay Storage #42
Looks good. Why didn't you stack the bales on gravel or pallets? Just curious.
/ Hay Storage #43
A major hay producer down the road from me just built a 150'X65'X18' barn. (side walls and roof nothing else) He said he was losing to much due to being stored outside under tarps. I assume he figured it was cost effective to build. Would you not benefit the same way? He sells 100% percent of what he grows, so bad hay does hit him hard in the pocket book.
Do you use your hay or sell it? Just curious.
x
/ Hay Storage #44
10,000 square feet sounds perfect!
/ Hay Storage
x
Oh I'd benefit but a hay barn isn't in the budget yet. I'm looking to grow, if so, I do I may end up moving my hay storage area. So I'm not ready to commit to the expense of the permanent structure. Although a 30x50 in that same spot wouldn't be bad.
I feed 95% of my hay. I sell very little.
/ Hay Storage #46
Plus the height. He can drive his bale wagon in and unload. It's a great set up. His family has been farming here for over 100 years and he just built the barn so think of the wasted hay over the years.
/ Hay Storage #47
OK, best of luck to you. One way or the other these things usually work out.
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
E-Z TRAIL 1020 GRAIN CART (A64278)
E-Z TRAIL 1020...
2017 Nissan Altima Sedan (A64557)
2017 Nissan Altima...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
2019 Mercedes-Benz GLS 4 Matic AWD SUV (A64557)
2019 Mercedes-Benz...
2020 McCloskey R155 Trommel Screener (A64553)
2020 McCloskey...
