Hay Storage Small Squares
/ Hay Storage Small Squares #21
We charge + $1.00 for a bale in the barn versus picked up in the field. If we ever delivered we would also have to probably add + $1.00.
Yep and like I said I have no problem w the guy wanting the premium. I am just trying to figure what I can store.
So basically I told him out of second cutting I want 1500. He will deliver what he can out of the field and store the balance.
/ Hay Storage Small Squares #23
we pay $3.75/bale for delivered and stacked and have maybe 100-150 at a time in place, on pallets, on a dirt floor in a barn. You can walk around the pile, used ot have it in a stall area (2 walls, was a teasing stall at one point in history so a short wall on another side). Worked well (put chickens in there over the winter).
Considering doing hay or looking at other options now that we havea tractor that can do it, can lift/stack large squares and rounds. Feed rounds in the winter -a bit wasteful but a lot less work than taking haw out to the pasture twice a day in the cold, snow and dark. No feeder, just dump them on the ground. An 800lb bale delivered is about $50.
Wha'ts nice is we can find (at auction..have to find a supplier) that does the large square bales - they come off in flakes and are about the same price and size as round bales, someteimes a big bigger for more money, but MUCH easier to stack/handle and feed.
IF we do hay a building is part of the equation to store it, figure 1000-1200 bales annual yield so a facility to hold all that. Either small rounds (under 80lb) or squares. Manhandling all that hay is a consideration. Still looking over our options.
With the price of oats of late i'm tempted to grow that instead. Older combines can be had for under $15k, or maybe I can hire the harvest out. Just started thinking on it this week as our oat supplier (a feed mill) can't get oats and we were paying $6-8/50lb and now have to go to agway/tsc/rk and pay closer to 20-21/50lb.
As a 'business' it's all abut the numbers - either it pays to do it, or not.
And too often you can end up going down the road to a place you never expected...instead of paying for snow removal and brush hogging I got us an old kubota - $1500. Very slow to brush hog so WTF, got a new Kioti for $23,000. WAY nicer, loader now too, bigger brush hog...but it's probably cheaper to pay someone to do the work..at least over a 10 year period. Nice to have control and get the job done when YOU want it done though.
Like hay and oats...we're on our third feed supplier this year...getting it deliverd, or getting it at all, is the issue. With 7 horses (some boarded) constantly fetching feed sucks.
/ Hay Storage Small Squares #24
I don't see why you're agonizing over hay storage. It's simple. Here's a shed I built myself: 20 x 28 ft, 11 ft height in front, 10 ft height in rear, 28 ga metal sides and roof. Total material cost: $3600. Simple design. Easy to build.
Good luck
/ Hay Storage Small Squares #25
$3,000 for a shipping container sounds like a lot. You may want to consider an older, not road worthy trailer as in tractor trailer. My partner had one 20 years ago that I think he either got for the taking, or maybe traded some landscaping for. Not pretty, but it really held a lot. 62 feet by8 feet by 8 feet is close to 4000 cubic feet. He had his planted close to ground level in a backhoe dug pit. Backed the trailer into it.
/ Hay Storage Small Squares #26
In my small hay business I usually charge 1$ extra to store. I don't deliver, but I will load with my tractor and hay grapple (included in cost) I have several replete customers that I cut deals with for 200 or more bales at a time. I usually sell out every year. If you have a good flat spot with good drainage you could stack the bales on pallets and cover with a good hay tarp or tarps (stack the top for drainage). That is how I started out. Whatever you do , do not stack on near ground or gravel, etc. Even concrete. It will wick water into the bottom row. You could probably build a hay shed pole barn cheaper (tax write off) and have it pay for itself in 5 years or less. Just make sure it is tall enough for whatever equipment you use. I no longer need to handel my bales by hand as I have this small grapple (205 model). Specialty Grabbers | Kuhns Mfg LLC | North Bloomfield, OH
Hope this helps.
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
CHANDLER 10' STAINLESS STEEL FERTILIZER SPREADER (A64277)
CHANDLER 10'...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
Atspower Mini Excavator (A60352)
Atspower Mini...
