Rake hay rake
/ hay rake
If it's not a copy, it's a Vermeer rake, isn't it?
What if we compare it to Sitrex's RP models?
Sitrex's original models too look good.
Also, which? tedder-rake or hay-rake to rake the hay?
Tedder-rake seems to be better.
/ hay rake #3
Nomad,
Its a vermeer
http://www.vermeerag.com/equip/vrake.html
I think its actually the smallest wheel rake they make.
I have been quite happy with it so far.
The one negative about this type of rake is that it does not distrub the center area only brings in the grass from the outside in. Therefore, the grass that was in the inner 52" prior to raking does not stick up as well and the baler may miss some of it depending on the conditions of the field and hay.
The good part of this rake is that it makes creating nice square bales quite easy since you are sure that the final windrow is the right width for the baler.
With a side discharge rake it takes more skill to get the windrow the right width. If the windrow is to narrow your baler will not be feed in a unfiorm way and the final bale will be barrel shaped and not shed water as well.
Fred
/ hay rake #4
Nomad,
I don't know much about the stirex...
http://www.sitrex.com/menu_hay_rakes.htm
But they are clearly three point mount rather than towed like the vermeer.
The towed is much easier to connect up but requires a hydraulic outlet. You can tow these rakes with very little hp. My tractor is just idiling along with this rake in tow.
The wheel arms of the towed vermeer lift up for transport so the entire width is only about 7-8' when transported. Its quite tall when folded up which is how you store it. Forget trying to get this in a garage even with a 9' door.
Think about support. I went with vermeer because the local dealer is very good. Lots of support and part avilability.
Fred
/ hay rake
Ok, I will speak like a child (because of my less use of English in my daily life.) But I guess you will understand what I mean.
I am still thinking about this;
What I see there is that their main difference of Sitrex and Vermeer rakes is in their connection type; 3-pt connection and 1-pt connection (or towed connection you name), respectively.
If they are doing exactly the same work, i.e. raking the hay, then why is there that difference? One of these connections has any superiority to the other? Lets say I am about to decide on purchasing a rake and this connection type will make me give my final decision. Any comment from you or from other people on this?
/ hay rake
I am still thinking about advantages&disadvantages of 3-pt and 1-pt (tow) mounted rakes. Slow thinker;]
The difference in the balance? Balance in 3-pt is better than that in 1-pt?
But, technically, all I can see is 2-pt connections in both types of 3-pt and 1-pt. Maybe, I need to sleep a little to clean my eyes lol.
/ hay rake #7
Nomad,
As far as how they function I don't think you will find a big difference.
The towed version will require you to avoid sharp turns or lift up the rake wheels when you trun sharply.
Biggest difference is connection time. The three point requires three pins and clips that all must be lined up. Not a big deal, but the towed one is just a single pin and the hydraulic connectors. Much easier.
Cost may be the big issue for you. I don't know for a fact but I suspect that the 3-point is cheaper.
Fred
/ hay rake #8
Nomad is trying to figure out which model to copy & manufature in Turkey. /forums/images/graemlins/wink.gif
The 3-point model requires a tractor with a 3-point.
The towed model requires a tractor with a hyd port.
That may seem obvious, but if you have an older tractor, it could sway your choice. /forums/images/graemlins/smile.gif
Also if you have a tractor you can dedicate to leave the rake on for much of haying season, a 3-point might be better.
If you need to take it off & on a tractor a lot, or would like to transport the rake some distance behind a pickup frequently (different farms miles apart, each with a utility tractor there) the towed one might be better.
I've not used either style, but am looking for a 4-5 wheel Sitrix style one of these days when i can afford it - it seems they have a bit of spring in the upper mounting, and are supported by the 3-point all the time. Do the big 2-wing models work the same way? And is it better to have wheels under a towed version to carry it over contured ground, or do the 3-point models flow over the ground just fine?
--->Paul
/ hay rake #9
Guys,
I have limited experince with the 3-point model but they look like they would be a pain to hook up. That is why I have the towed version. Its like any towed ag implement, just drop the pin in place. Its also light enough that I can move the tongue around and do not have to align the tractor up perfectly.
Here is a shot of the whole rake in storage mode.
It will not fit in my shop/garage and its a 9-10' door. If you adjust the arms you can make it just under 10' feet but then you will need to adjust it everytime you use it for the proper width.
Fred
/ hay rake #10
Here is a shot of the lift cylinder.
Note the red metal part. This holds the arms up when the hydraulics are not connected up to the tractor. You pull this off when you want to use it. Then just hit the hydrualic tractor controls to raise and lower as needed.
Fred
/ hay rake
Rambler, you don't have any rake yet? I have. With 5 fingers raking.. money the dirt. This was a saying of my old old grandpa "money is a hand dirt - you wash your hand - and, it gets dirty again." Yes, I have met some nomads who make copies of copies of copies of...items. I have seen one nomad on Newagtalk who does such things. Anyways..
Phred,
Human life is really colorful... but, that colorfulness is almost always because of misunderstandings. Here we see another one. I thought you were talking about "carted rakes with hydraulic lifts" when you were talking about "3-pt" mounted rakes. I have seen (on web sites) some carted rakes, but all were rakes with towed mounted. Never seen 3-pt carted rake. So, actually you were talking about non-hydraulic side delivery rake when you were talking about 3-pt mounted rake.
/ hay rake #12
My hands are pretty dirty tonight from combining all day! /forums/images/graemlins/smile.gif Unfortunately I have more dirt than money, so haven't purchased a rake yet. I do have a pretty good older NH rollabar rake, but would like a wheel rake for some occations - and backup for breakdowns. So I'm in no hurry. /forums/images/graemlins/smile.gif
I think Phred's rake is on a cart? I believe they are very similar, the 3-point Vermeer is about the same as the pull type. The pull type is a bit more money because of the axle, 2 tires, and such.
--->Paul
/ hay rake
It seems (from forum talks on the net) that "rotary rake" is more popular among farmers. Most of them are planning to buy rotary rakes as soon as they harvest a little crops more.
An alternative; Built-your own V-rake yourself. All you will need are 1 simple pto shaft + 2 pulleys each of it transmitting the PTO motion to one side of rake tines. These a few rake tines (like rotary rake tines) can move like a tank pallet, following a vertical elliptic motion unlike rotary rake tines which follow horizontal circular motion.
2013 Land Rover Range Rover AWD SUV (A64557)
2013 Land Rover...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
48x4 Mini Skid Trencher (A63689)
48x4 Mini Skid...
2003 Isuzu NPR Box Truck, VIN # 4KLB4B1R13J801508 (A65563)
2003 Isuzu NPR Box...
2018 Ford F-550 Altec AT37G 37ft. Insulated Bucket Truck (A64556)
2018 Ford F-550...
40' Used Container, High Cube, Single End Doors  (A62679)
40' Used...
