Hay Rake
/ Hay Rake #1
Nana
I have a 4150 New Idea Hay Rake. It won"t stay in gear when the right wheel is on the high side. Any ideas?
/ Hay Rake #2
Won't wont stay in gear?
Right wheel is on the high side of what?
D.
/ Hay Rake #3
Not familiar with this specific rake but ground driven equipment in general can suffer from accumulated looseness, worn splines, missing shims/pins. Gravity is having some effect if you only have the problem when on a side hill. Some part is also sliding downhill. Do you have to re-engage manually or does it self correct? Does the drive shaft still turn when this occurs? Is there a missing detent ball or weak spring that allows the transmission to come out of gear? Is there a missing shim / spacer allowing gears to disengage? Are wheel bearings allowing the whole rake to slide slighty downhill away from the drive wheel? Here's a parts manual for short money that might help you see where the problem could be. New Idea 4150, 4151, 4160, 4161, 4170, 4171, 410, Hay Rake parts MikeD74T
(2) Trailer Axles (A64912)
(2) Trailer Axles...
2017 FREIGHTLINER CASCADIA  125 6x4 T/A  SLEEPER TRUCK TRACTOR (A69167)
2017 FREIGHTLINER...
2012 HINO 268 4X2 S/A BOX TRUCK (A59914)
2012 HINO 268 4X2...
275/70R19.5 Tire and Wheel (A68134)
275/70R19.5 Tire...
Kubota 60in. Zero Turn Commercial Mower (A66734)
Kubota 60in. Zero...
2019 CHEVROLET TAHOE (A66091)
2019 CHEVROLET...
