Hay Rake
/ Hay Rake #1
Nana
I have a 4150 New Idea Hay Rake. It won"t stay in gear when the right wheel is on the high side. Any ideas?
/ Hay Rake #2
Won't wont stay in gear?
Right wheel is on the high side of what?
D.
/ Hay Rake #3
Not familiar with this specific rake but ground driven equipment in general can suffer from accumulated looseness, worn splines, missing shims/pins. Gravity is having some effect if you only have the problem when on a side hill. Some part is also sliding downhill. Do you have to re-engage manually or does it self correct? Does the drive shaft still turn when this occurs? Is there a missing detent ball or weak spring that allows the transmission to come out of gear? Is there a missing shim / spacer allowing gears to disengage? Are wheel bearings allowing the whole rake to slide slighty downhill away from the drive wheel? Here's a parts manual for short money that might help you see where the problem could be. New Idea 4150, 4151, 4160, 4161, 4170, 4171, 410, Hay Rake parts MikeD74T
2008 Dodge Daytona R/T Charger (A64911)
2008 Dodge Daytona...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A67714)
GENERAC MOBILE...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2012 SHOPMADE T/A GOOSENECK TRAILER (A67714)
2012 SHOPMADE T/A...
2023 26ft Freedom Trailers Akurate Dynamics T/A Mobile Spray Foam Trailer (A64556)
2023 26ft Freedom...
