Hay Rake
/ Hay Rake #1
Nana
I have a 4150 New Idea Hay Rake. It won"t stay in gear when the right wheel is on the high side. Any ideas?
/ Hay Rake #2
Won't wont stay in gear?
Right wheel is on the high side of what?
D.
/ Hay Rake #3
Not familiar with this specific rake but ground driven equipment in general can suffer from accumulated looseness, worn splines, missing shims/pins. Gravity is having some effect if you only have the problem when on a side hill. Some part is also sliding downhill. Do you have to re-engage manually or does it self correct? Does the drive shaft still turn when this occurs? Is there a missing detent ball or weak spring that allows the transmission to come out of gear? Is there a missing shim / spacer allowing gears to disengage? Are wheel bearings allowing the whole rake to slide slighty downhill away from the drive wheel? Here's a parts manual for short money that might help you see where the problem could be. New Idea 4150, 4151, 4160, 4161, 4170, 4171, 410, Hay Rake parts MikeD74T
PALLET OF MISC WHEELS (A67714)
PALLET OF MISC...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63689)
2023 Kubota...
2017 Case IH Farmall 140A (A64911)
2017 Case IH...
2013 CHEVROLET CAPRICE CAR (A66091)
2013 CHEVROLET...
JCT 72" QA Snow Bucket (A64912)
JCT 72" QA Snow...
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A64279)
2026 DEVELON...
