Hay now!
/ Hay now! #3
Digger,that unloading in 2010 was significantly cleaner than the one in 2009. I think your learning curve is on the rise.:thumbsup:
/ Hay now!
Your rite, some yrs things just seem to go better than others. Its all about the preperation.
/ Hay now! #5
Work smart not hard. ;)
/ Hay now! #6
How'd you do that? Are you using a slip sheet between the trailer and the hay? Or maybe an anchor with a cable running to a bar at the front of the trailer? Or?
/ Hay now!
Its easy, I have the bottem bales stacked on thier sides so they will clear the fenders, then I stand a couple of 2x6s up at the front corners of the stack and then put my straps around the stack to hold it together like a block. This yr I was hooked to my backhoe some yrs I backup to a tree, just depends on where I want to stack it. The steel deck and slight bever tail on my trailer seems to help make it work. I do know I am never unloading by hand again! Glad you guys liked it.
/ Hay now! #9
Neato:thumbsup:
So, how to you load that lowboy trailer--by hand? Other?
/ Hay now! #11
They hand load it where I buy my hay.
Ah--the most important word "they":D
My back aches just looking at the size of that load that you're carrying on that trailer:)
2014 Lincoln MKS Sedan (A64557)
2014 Lincoln MKS...
2014 Toyota Tundra Crew Cab Pickup Truck (A64194)
2014 Toyota Tundra...
2018 Toyota Camry Sedan (A64557)
2018 Toyota Camry...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 INTERNATIONAL...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A65053)
2018 CATERPILLAR...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Straight Boom Crane Truck (A64194)
2015 Kenworth T880...
