Hay now!
/ Hay now! #3
Digger,that unloading in 2010 was significantly cleaner than the one in 2009. I think your learning curve is on the rise.:thumbsup:
/ Hay now!
Your rite, some yrs things just seem to go better than others. Its all about the preperation.
/ Hay now! #5
Work smart not hard. ;)
/ Hay now! #6
How'd you do that? Are you using a slip sheet between the trailer and the hay? Or maybe an anchor with a cable running to a bar at the front of the trailer? Or?
/ Hay now!
Its easy, I have the bottem bales stacked on thier sides so they will clear the fenders, then I stand a couple of 2x6s up at the front corners of the stack and then put my straps around the stack to hold it together like a block. This yr I was hooked to my backhoe some yrs I backup to a tree, just depends on where I want to stack it. The steel deck and slight bever tail on my trailer seems to help make it work. I do know I am never unloading by hand again! Glad you guys liked it.
/ Hay now! #9
Neato:thumbsup:
So, how to you load that lowboy trailer--by hand? Other?
/ Hay now! #11
They hand load it where I buy my hay.
Ah--the most important word "they":D
My back aches just looking at the size of that load that you're carrying on that trailer:)
