Hay now!
   / Hay now! #3
Digger,that unloading in 2010 was significantly cleaner than the one in 2009. I think your learning curve is on the rise.:thumbsup:
   / Hay now!
Your rite, some yrs things just seem to go better than others. Its all about the preperation.
   / Hay now! #5
Work smart not hard. ;)
   / Hay now! #6
How'd you do that? Are you using a slip sheet between the trailer and the hay? Or maybe an anchor with a cable running to a bar at the front of the trailer? Or?
   / Hay now!
Its easy, I have the bottem bales stacked on thier sides so they will clear the fenders, then I stand a couple of 2x6s up at the front corners of the stack and then put my straps around the stack to hold it together like a block. This yr I was hooked to my backhoe some yrs I backup to a tree, just depends on where I want to stack it. The steel deck and slight bever tail on my trailer seems to help make it work. I do know I am never unloading by hand again! Glad you guys liked it.
   / Hay now! #8
Ya did good!!
   / Hay now! #9
Neato:thumbsup:
So, how to you load that lowboy trailer--by hand? Other?
2014 FORD F-350 SUPER DUTY (A52472)
2014 FORD F-350...
2019 Ford F-550 Truck, VIN # 1FDUF5GT5KDA27067 (A51572)
2019 Ford F-550...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
Year: 2012 Make: Honda Model: Accord Vehicle Type: Passenger Car Mileage: 91,438 Plate: Body Type... (A51694)
Year: 2012 Make...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A52748)
John Deere 6105E...
