Hay mower
/ Hay mower #1
qed-cat225
Sullivan, WI
2011 Bobcat CT235
other than a sickle mower is there any other type of Hay mower a CT235 could handle on a small scale?
/ Hay mower #2
A "drum mower" would be well suited to your small tractor.
/ Hay mower #4
Right on. Get a 5-ft drum mower. Cost will be about $3K plus shipping (about half the cost of a similar size disc mower). Drums will not clog like sicklebar mowers, will cut any type of vegetation regardless of the moisture situation, cut fast at high ground speed, are simple machines that require minimal servicing, and the blades are inexpensive and quickly and easily changed in the field.
Good luck.
/ Hay mower #6
Kuhn and Kubota make a small one and there are several itiallian ones out there. I would suggest you first rent one from your local AGG dealer or rental place that handle agg equipment. I run a 9' IH 1300 sickle mower with no issues. does very well for me.
/ Hay mower #7
One other question - what do you plan to use for a rake and baler?
/ Hay mower #8
/ Hay mower
thanks for the google advice i had not thought of that...
/ Hay mower #10
I have owned the ranch rite drum mower for two years. Works fine on my CT235.
GASPARDO V-20-8 5 PANEL VEGETABLE VACUUM PLANTER (A64276)
GASPARDO V-20-8 5...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61573)
2022 Peterbilt 567...
2015 Nissan Leaf Hatchback (A61574)
2015 Nissan Leaf...
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
2024 Ford Transit Box Van, VIN # 1FDRU6ZG8RKB10273 (A65563)
2024 Ford Transit...
KUBOTA 72" PIN ON BUCKET (A64280)
KUBOTA 72" PIN ON...
