Hay mower
/ Hay mower #1
qed-cat225
Gold Member
Sullivan, WI
2011 Bobcat CT235
other than a sickle mower is there any other type of Hay mower a CT235 could handle on a small scale?
/ Hay mower #2
A "drum mower" would be well suited to your small tractor.
/ Hay mower #4
Right on. Get a 5-ft drum mower. Cost will be about $3K plus shipping (about half the cost of a similar size disc mower). Drums will not clog like sicklebar mowers, will cut any type of vegetation regardless of the moisture situation, cut fast at high ground speed, are simple machines that require minimal servicing, and the blades are inexpensive and quickly and easily changed in the field.
Good luck.
/ Hay mower #6
Kuhn and Kubota make a small one and there are several itiallian ones out there. I would suggest you first rent one from your local AGG dealer or rental place that handle agg equipment. I run a 9' IH 1300 sickle mower with no issues. does very well for me.
/ Hay mower #7
One other question - what do you plan to use for a rake and baler?
/ Hay mower #8
/ Hay mower
thanks for the google advice i had not thought of that...
/ Hay mower #10
I have owned the ranch rite drum mower for two years. Works fine on my CT235.
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
2013 Ford Escape AWD SUV (A61574)
2013 Ford Escape...
2004 Dodge Sprinter 2500 Cargo Van (A61573)
2004 Dodge...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
2026 Kearney 102"x32' Gooseneck Trailer (A64119)
2026 Kearney...
2020 VOLVO EC200EL EXCAVATOR (A65053)
2020 VOLVO EC200EL...
