Hay Mower ?
/ Hay Mower ? #1
purplewg
Does anyone know if the hydraulic cylinders on hay mowers are single or dual action. When hooked to the tractor with nothing on it, it won't extend. I assume the weight has been making it go down. Goes up with no problems.
/ Hay Mower ? #2
Do the cylinders have 1 hose or 2 attached to them?
DA cylinders require 2 hoses, one at the base and one at the top where the piston comes out.
/ Hay Mower ?
Just a hose on one end. I never paid any attention. I just assumed it would push or pull. So, one hose is a one-way operation? THanks
/ Hay Mower ? #4
what type of haymower do you have? my old jd sickle has a cylinder w/ 2 hoses. 1 hose allows the cylinder to open out for lift and the other is the return to allow it to retract, lower the cutter bar. if its not extending you may not have enough hyd pressure to make it extend or possibly a low fluid condition.
/ Hay Mower ? #5
If the cylinder has just one hose, then it is a SA (single acting) cylinder. Usually gravity or spring pressure is used to retract them.
/ Hay Mower ?
OK thanks. In my case it is the shear weight that pulls it down and my hyd system pulls it up.
213121 (A64276)
213121 (A64276)
2006 Ford F-450 Crew Cab 9ft. Stakebody Flatbed Truck (A66736)
2006 Ford F-450...
2004 CHEVROLET MALIBU 4 DOOR CAR (A66091)
2004 CHEVROLET...
Unused 2023 Del Morino CS158M Agricultural Flail Mower Tractor Attachment (A66734)
Unused 2023 Del...
Unused 2023 Hustler Regener8r LM630 Hydraulic Chain Harrow Tractor Loader Attachment (A66734)
Unused 2023...
2022 JCB Fastrac 4220 217HP 4WD Agricultural Tractor (A66734)
2022 JCB Fastrac...
