Hay Mower ?
/ Hay Mower ? #1
purplewg
Does anyone know if the hydraulic cylinders on hay mowers are single or dual action. When hooked to the tractor with nothing on it, it won't extend. I assume the weight has been making it go down. Goes up with no problems.
/ Hay Mower ? #2
Do the cylinders have 1 hose or 2 attached to them?
DA cylinders require 2 hoses, one at the base and one at the top where the piston comes out.
/ Hay Mower ?
Just a hose on one end. I never paid any attention. I just assumed it would push or pull. So, one hose is a one-way operation? THanks
/ Hay Mower ? #4
what type of haymower do you have? my old jd sickle has a cylinder w/ 2 hoses. 1 hose allows the cylinder to open out for lift and the other is the return to allow it to retract, lower the cutter bar. if its not extending you may not have enough hyd pressure to make it extend or possibly a low fluid condition.
/ Hay Mower ? #5
If the cylinder has just one hose, then it is a SA (single acting) cylinder. Usually gravity or spring pressure is used to retract them.
/ Hay Mower ?
OK thanks. In my case it is the shear weight that pulls it down and my hyd system pulls it up.
2011 MAGNUM TRAILER LIGHT PLANT (A67714)
2011 MAGNUM...
Steiner 60in Fairway Mower Tractor Attachment (A64553)
Steiner 60in...
2015 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2015 FREIGHTLINER...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A66736)
2017 Ford F-150...
2015 CHEVROLET CAPRICE POLICE CAR (A66091)
2015 CHEVROLET...
Hoelscher 110 Bale Grapple (A64126)
Hoelscher 110 Bale...
