Hay Mower ?
/ Hay Mower ? #1
purplewg
Does anyone know if the hydraulic cylinders on hay mowers are single or dual action. When hooked to the tractor with nothing on it, it won't extend. I assume the weight has been making it go down. Goes up with no problems.
/ Hay Mower ? #2
Do the cylinders have 1 hose or 2 attached to them?
DA cylinders require 2 hoses, one at the base and one at the top where the piston comes out.
/ Hay Mower ?
Just a hose on one end. I never paid any attention. I just assumed it would push or pull. So, one hose is a one-way operation? THanks
/ Hay Mower ? #4
what type of haymower do you have? my old jd sickle has a cylinder w/ 2 hoses. 1 hose allows the cylinder to open out for lift and the other is the return to allow it to retract, lower the cutter bar. if its not extending you may not have enough hyd pressure to make it extend or possibly a low fluid condition.
/ Hay Mower ? #5
If the cylinder has just one hose, then it is a SA (single acting) cylinder. Usually gravity or spring pressure is used to retract them.
/ Hay Mower ?
OK thanks. In my case it is the shear weight that pulls it down and my hyd system pulls it up.
2018 Chevrolet Silverado 3500 Royal Service Truck (A64194)
2018 Chevrolet...
HONDA Plate Compactor (A64557)
HONDA Plate...
Forest River Freedom Express RV Trailer (A64557)
Forest River...
2011 Kenworth T300 S/A 18ft. Cab and Chassis Truck (A64194)
2011 Kenworth T300...
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
207923 (A63290)
207923 (A63290)
