Hawse Fairlead
/ Hawse Fairlead
I do have a mile marker 10,500 hyd winch that I use on my tractor for skidding logs. Having a winch on an ATV/RTV is for ocassional use so I would think that an electric one would last a long time. When I use my hyd one it goes in and out like a yo yo going up and down.
/ Hawse Fairlead #22
my warn is about 4 years old and it's still tugging along but i keep it cleaned and lubed up. i need to upgrade to a 4k warn though with everything i keep adding to the hpx the 2500 warn is maxing out but it still pulls me out (when i do get stuck)
/ Hawse Fairlead #24
TWO GUNS said:
learstroker said:
its a 5400 lb hyd. mile marker. It can work underwater. It can go front or back. Its from Winches Plus
Went to that website, them winches are not priced as I would have guessed. They are priced fair !!!!
With the 2 speed 70-series $760 hydraulic model you get a free hat. :)
/ Hawse Fairlead #25
But can the rtv motor run under water? :D :D
Hydraulic winches are perfect in every way but this. My electric Ramsey is waterproof and should work underwater...
/ Hawse Fairlead #26
if you have this air intake it will
/ Hawse Fairlead #27
my warn 2500 works underwater. all 12 volt motors should work under water .well i should say dc current motors should work underwater it's the elctronic boards that can't get wet and as far as i know their ain't no circut boards in a winch.
/ Hawse Fairlead #28
AS LONG AS I KEEP MY EYES OUT OF THE WATER, IT WILL RUN !!!!
/ Hawse Fairlead
Their winchs with a steel cable leave a lot to be desired. Unless they have change the way they attach the cable to the drum. I have redsigned the one I got from them 2 times and now I have a fairly good winch.
1997 FRAC TANK 500BBL WHEELED (A68842)
1997 FRAC TANK...
2023 Chevrolet Tahoe SUV (A66738)
2023 Chevrolet...
TRAILER (A66736)
TRAILER (A66736)
2018 PETERBILT 579 (A67714)
2018 PETERBILT 579...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
2015 Toyota RAV4 SUV (A61574)
2015 Toyota RAV4...
