Hawse Fairlead
/ Hawse Fairlead
I do have a mile marker 10,500 hyd winch that I use on my tractor for skidding logs. Having a winch on an ATV/RTV is for ocassional use so I would think that an electric one would last a long time. When I use my hyd one it goes in and out like a yo yo going up and down.
/ Hawse Fairlead #22
my warn is about 4 years old and it's still tugging along but i keep it cleaned and lubed up. i need to upgrade to a 4k warn though with everything i keep adding to the hpx the 2500 warn is maxing out but it still pulls me out (when i do get stuck)
/ Hawse Fairlead #24
TWO GUNS said:
learstroker said:
its a 5400 lb hyd. mile marker. It can work underwater. It can go front or back. Its from Winches Plus
Went to that website, them winches are not priced as I would have guessed. They are priced fair !!!!
With the 2 speed 70-series $760 hydraulic model you get a free hat. :)
/ Hawse Fairlead #25
But can the rtv motor run under water? :D :D
Hydraulic winches are perfect in every way but this. My electric Ramsey is waterproof and should work underwater...
/ Hawse Fairlead #26
if you have this air intake it will
/ Hawse Fairlead #27
my warn 2500 works underwater. all 12 volt motors should work under water .well i should say dc current motors should work underwater it's the elctronic boards that can't get wet and as far as i know their ain't no circut boards in a winch.
/ Hawse Fairlead #28
AS LONG AS I KEEP MY EYES OUT OF THE WATER, IT WILL RUN !!!!
/ Hawse Fairlead
Their winchs with a steel cable leave a lot to be desired. Unless they have change the way they attach the cable to the drum. I have redsigned the one I got from them 2 times and now I have a fairly good winch.
2023 New Holland C327 High Flow Compact Track Loader Skid Steer (A61572)
2023 New Holland...
2007 Toyota Camry Sedan (A61574)
2007 Toyota Camry...
213093 (A64276)
213093 (A64276)
2015 GMC Sierra 1500 Crew Cab Pickup Truck (A61573)
2015 GMC Sierra...
2012 MACK GU713 DUMP TRUCK (A63276)
2012 MACK GU713...
2022 Chevrolet Tahoe SUV (A61574)
2022 Chevrolet...
