Have You Burned Poplar ?
/ Have You Burned Poplar ? #1
scott_vt
Super Member
east wells,vt
1986 MF 1040, 1942 Farmall A, 1949 Farmall Super A
Good Mornin Guys,
I know its not considered great firewood, I believe ts considered a hardwood, but the softest in that category !
I have a chance to get a real load of this stuff from a neighbor, it has been cut into rounds, and just needs to be transported up the street and then split...
Is it more trouble than its worth, I thought it might be OK for the early fall season while its not too cold...
It should split easily ! :) Thanks foryour opinions ! ;)
I normally burn oak, maple, birch etc...
/ Have You Burned Poplar ? #2
I have two wood sayings
"Soft wood for the soft times and hard wood for the hard times."
and
"If it's wood, it's good"
I've burned lots of poplar to start fires or when I need a quick one that I want to burn out. If I have a lot I'll mix it through the hardwood so there is one poplar chunk for ever dozen or so hardwoods. Splits into great kindling too.
I'd take it.
/ Have You Burned Poplar ? #3
I had two big Tulip Poplar trees in my yard I had cut down. What hasn't gone through my sawmill went through my fireplace. I think it burns good enough for me.
/ Have You Burned Poplar ? #4
Scott I use poplar for early season and late season. It splits so easily it is also great to make kindling from. Makes for pleasant fires but use a screen or door on your stove because it does pop.
MarkV
/ Have You Burned Poplar ? #5
If its free, then use it. Considerations to take into account: Poplar burns fast and gives off little heat compared to other wood. If you decide to use it, make sure that it is dried out before burning it. Use the poplar to help start your fire and then add hardwood if you want a longer lasting fire. You will expend little energy in splitting the wood, because it splits easily. If you have yellow poplars close to your Home, I would advise removing them. They are subject to being blown down when heavy winds are prevalent. Shiitake mushroom growers, sometimes utilize poplar logs as a growing medium, although I think the use of oaks is more prevalent. In case you like mushrooms that are good eating, and you decide to grow them, there is a thread circulating here on TBN in reference to growing Shiitake Mushrooms. Just a thought?
/ Have You Burned Poplar ? #6
Yes, I've burned it. I'll burn anything.
/ Have You Burned Poplar ? #7
Yep, I wouldn't turn it down. Free heat, may not burn as long as oak, maple or locust but it will burn. It seasons fast and like others said, makes splits easy for nice kindling.
/ Have You Burned Poplar ? #8
I agree with all posters- If it free and easy to get to, then use it. I use popular in fall and spring whenever I want to warm up the house but dont want the fire going, or dont want a hot fire and it keeps me busy adding wood. :thumbsup:
usually I try to cut and split the popular trees where it falls and wait a season or two before moving it to my wood pile. This does two things for me- It makes the wood easy to move and I can pile a heck lot more in my trailer if going long distance.
using popular wood makes me feel good about saving the hardwood trees for future use.
/ Have You Burned Poplar ? #9
you can have all my cottonwood for free if you want
/ Have You Burned Poplar ? #10
There are basically 2 kinds of poplar being discussed here........In the north it is small in diameter and short lived........The southern tree, tulip poplar grows up to 3' in diameter and lives quite a long life............Both are soft, burn readily, and are really trash trees as far as the wood burning situation.......Tulip poplar though, is used for pulp and as cheap hidden parts of furniture, such as couch frames.........
Anyway........for me.....neither is great for heat production and they are treated as weed type trees in my firewood harvesting efforts.......God bless........Dennis
/ Have You Burned Poplar ? #11
FREE always burns good...
Army Grunt
Good Evenin Guys,
Thanks for all your input ! I just got one good trailer load and will go back for a few more. As Jimmy and others have said I will just mix it in with the good stuff and use it for getting the fire going again and for spring and fall use !
Some of the rounds are rather large but it does spit quite easily, and should provide some amount of heat anyway ! ;):)
Free is allways good ! :thumbsup:
/ Have You Burned Poplar ? #13
I burn poplar when it is available, dried, and rot-free. I use wood harvested from my place to heat with a wood furnace. Trees available in order of numbers are fir, birch, pine and poplar. In order of what I burn are pine, birch, fir and poplar, with pine + birch five times the amount of fir + poplar. The order is mainly due to harvesting when the trees are at or near the end of their life cycle.
I've attached a previous post's link to a useful chart from the book "Firewood and Your Chain Saw". It is interesting to see the heat values for different species.
http://www.tractorbynet.com/forums/...ucket-load-firewood-weight-firewoodweight.pdf
/ Have You Burned Poplar ? #14
We've got all kinds in the north, quaking aspen, big tooth aspen, tulip, cottonwood, you name it.
/ Have You Burned Poplar ? #16
Yes, I've burned Poplar to erase any and all evidence that I thoroughly screwed up a wood project.:laughing:
/ Have You Burned Poplar ? #17
I've heard it said that there is more creosote in poplar (like softwood) than there is in the traditional hardwoods.
/ Have You Burned Poplar ? #18
The Haymaker said:
I have a bunch of box alder I'll give you.
Army grunt between haymakers alder and my cottonwood you'll be able to burn free for a long time
/ Have You Burned Poplar ? #19
I have a wood burning neighbor who orders a load of popple ( aspen ) from me every year. He uses it fall and spring in his kitchen stove for those "I need a quick fire" times. I burn some too.
/ Have You Burned Poplar ? #20
Just be careful with it Scotty as it will burn hot and quickly. Typical type of fire that start the chimney a blaze.
Wayne
