Have we been doing it wrong? High rpm's bad when not needed?
   / Have we been doing it wrong? High rpm's bad when not needed? #61
I see Coleman's offers new substrate cannisters for sale but again, extinguishing the light fall to a dealer with the correct diagnosis tools, IOW the updated Diagmaster.
   / Have we been doing it wrong? High rpm's bad when not needed? #62
I run older tractors mostly. I still do not use higher RPMs because among other things its the best way for a diesel engine to rip out a clutch under a load.....
Not gonna happen ever with a properly tensioned pressure plate but a mal adjusted clutch can certainly have the facings removed and will slip.
   / Have we been doing it wrong? High rpm's bad when not needed? #63
The weakest link on your tractor by far is the transaxle (especially if its HST). Engines almost always exceed the life of the tranny.
High rpms do NOT hurt an engine at all but lowers the torque put on the engine and transaxle components. High torque is what wears and breaks tractors. So error toward higher rpms for longer tractor life.
I totally disagree with your comment for so many reasons it would take pages to list them. Suffice to say, you are dead wrong.
   / Have we been doing it wrong? High rpm's bad when not needed? #64
That's OK... we can disagree. My comments come from a 30 year career as a tractor engineer. I know what drives high strain on gaged machines (both in the field and lab tests), failure modes at end of life, and exactly how it all relates to warranty. It's also basic engineering:
Power = torque × rpm
As rpm goes up.... torque goes down as does wear and breakage. Best to error running a little faster for longest tractor life.
   / Have we been doing it wrong? High rpm's bad when not needed? #65
Why you only have 104 posts to date. How could you possibly be right and 5030 with his 25,000+ posts be wrong?
Better prepare yourself for all the "pages" of reasons you are wrong!
   / Have we been doing it wrong? High rpm's bad when not needed? #66
With over 60 years of running and repair tractors this is not the first time I have heard this and not the first time I have shrugged it off as bull.
It may be somewhat true on gas powered lawn tractors but I doubt it even there.
   / Have we been doing it wrong? High rpm's bad when not needed? #67
   / Have we been doing it wrong? High rpm's bad when not needed? #68
This is all pretty debatable. Another thread or two maybe
   / Have we been doing it wrong? High rpm's bad when not needed? #69
Not necessarily.
Totally dependent on the load % put on the engine.
At, say, a full 100% load, the torque increases as rpm’s go up, until you cross the rpm of maximum torque. Only then, does torque start decreasing with increasing rpm’s as you stated.
   / Have we been doing it wrong? High rpm's bad when not needed? #70
I own 2008 tractor, so it doesn’t have the ridiculous emissions junk on it, but I’m following this thread because I’m interested in anything ICE related.
One question I have for those unfortunate with the newer regen requirements…has anyone tracked diesel gallons between regenerations, instead of hours?
Running only required rpm’s uses less fuel. I’m guessing, even if the regeneration interval is shorter, I bet it’s at the same amount of fuel burned, or even less.
2008 GMC Savana 2500 Cargo Van (A59230)
2008 GMC Savana...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2022 CATERPILLAR 242D3 SKID STEER (A60429)
2022 CATERPILLAR...
2017 CATERPILLAR 120M2 MOTORGRADER (A59823)
2017 CATERPILLAR...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
Informational Lot - Financing (A56438)
Informational Lot...
