Have we been doing it wrong? High rpm's bad when not needed?
   / Have we been doing it wrong? High rpm's bad when not needed? #81
If you let it 'slide', what will happen is when it fills up with burned ash (soot), the engine will either derate of the cannister will expand and push the front or rear sealing rings apart and then derate. Seen that happen on Class 8 big trucks many times and when it does, not only will the element have to be replaced because it cannot be cleaned as it's deformed plus the cannister and everything attached to it has to be replaced as well. In a big truck it's referred to as the 'one box' and the bare box itself is in the excess of 1500 bucks not including labor and it's not a warranty item either as it's considered abuse. Additionally, Rudy designed the diesel engine to produce maximum torque at a lower RPM than a gas motor, consequently, I'd never buy a post 4 tractor simply because high rpm causes excessive engine wear. I rarely run any of my tractors at rated RPM anyway unless the implement I have on requires it, like my discbine mowing heavy hay because I have to keep the forage flow going to the crimp rolls continuously.
Of course the 'genus's at the EPA don't take that into account.
   / Have we been doing it wrong? High rpm's bad when not needed? #82
This graph shows soot production as a function of power and rpm. BMEP which is effectively torque is on the vertical axis and rpm on the horizontal axis. You can see there is a sweet spot of low soot right in the range where its putting out some power at a range of operating rpm. I don't know what engine its for or how much it changes for different engines but at least it's an idea of how it is for one engine.
You can tell that letting it idle with no load is going to generate many times more soot that working it.
Do you have supplemental information to go with this chart?
Normally BMEP maps are created from a specific quantity of fuel, like grams, or liters, etc. That would mean the lower the rpm on the plot , the less fuel would have been combusted for a given amount of time. We would need to know if the plot was compensated for this factor.
If the same quantity of fuel was combusted for each measured rpm point, then the lower rpm readings would have run longer to consume the fuel.
In other words, this may be a somewhat misleading plot without clarification
   / Have we been doing it wrong? High rpm's bad when not needed? #83
One thing I don't worry about is fuel consumption. One, my off road diesel is not taxable and two what it is is an expense write off anyway. Far as my on road is concerned, that is also a write off as my truck is a farm related vehicle.
I'm alarmed at what they cost but it's the 'gotta have it' deal so I don't get excited.
   / Have we been doing it wrong? High rpm's bad when not needed? #84
My Branson's tach has a green band from about 2000 to 2500 rpm. The manual says to keep the engine in that band for best DPF performance.
So you increase emissions longevity and decrease engine life from excessive RPM. Sounds counter productive to me...?
   / Have we been doing it wrong? High rpm's bad when not needed? #85
Curiously, what would happen if you just let it slide? Is it like a car with a check engine light where you can still drive it just fine for the most part, or does ignoring it cause serious problems?
If you ignore the regen light too long, or cancel it too many times, the ECM will go into a 'limp mode' and require the dealer to come out and reset it after doing the regen. I think Kubota is 3 or 4 skips.
Going too long without replacing/cleaning a clogging DPF means pretty much the same as a plugged catalytic converter as it plugs the exhaust. This can take thousands of hours though, unless you are constantly skipping regens.
   / Have we been doing it wrong? High rpm's bad when not needed? #86
If I’m pulling or plowing a given load “X”, the torque felt by the drivetrain will be the same regardless of engine RPM. Either the drive train is overcoming the load or it isn’t.
For instance, my pickup can drive a consistent 30 mph in 3rd, 4th, or 5th gear. The engine will be doing different RPMs based on the gear used, but the power to the ground, and the power felt by the components is the same. If the power were less, the pickup would slow down, and if it were more the pickup would speed up.
   / Have we been doing it wrong? High rpm's bad when not needed? #87
You’re acting like you can predict all tractor designs and makes into a predetermined part lifespan, and that, you, or nobody can do.
Ha... it's done everyday.
The MBAs that run the ag companies treat every product they make as an appliance. They ask engineering/marketing to set very defined capabilities and life goals so they can remain competitive. Remember the first microwaves? Brand new technology then. They were big, faux walnut boxes that sat on the counter. Makers thought Americans would  cook with them. We didnt, just reheated stuff. Those old things just wouldn't die! Quickly though, manufacturers caught on and dialed it back to a 8-9 year life.... you can set your watch by it. Tractors are no different.
Engineers are taught to use 'perfect design'. Just like the human body, all compnents should hit that life goal. When we get old the eyes, joints, hearing, thinking, etc all decline at about the same rate. Perfect design. The diesel engine in your tractor is typically designed so it could go into multiple applications though: stationary pumps, gen sets, industrial machines, ag, marine, etc which many times have a higher life goal. The tractor transaxle, however, is one of the most expensive components in the tractor and designed just for its application. It is the weakest link.
True!... from the motor back. From the pump forward it's not.
This shouldn't be this controversial. All I'm saying is it's better to error on the high side of throttle when you're working your tractor.
OP- Regular transaxle fluid changes per the OM is the single most important service your tractor gets.
   / Have we been doing it wrong? High rpm's bad when not needed? #88
The MPAs that run the ag companies treat every product they make as an appliance. They ask engineering/marketing to set very defined capabilities and life goals so they can remain competitive. Remember the first microwaves? Brand new technology then. They were big, faux walnut boxes that sat on the counter. Makers thought Americans would  cook with them. We didnt, just reheated stuff. Those old things just wouldn't die! Quickly though, manufacturers caught on and dialed it back to a 8-9 year life.... you can set your watch by it. Tractors are no different.
Just starting with your statement “the transaxle is the weakest link “ Is false on its own. Every tractor made, from every manufacturer, has weak and strong points. Pretty much any part failed, will put the tractor out of use.
If you open your mind up a bit, you would realize that starting batteries, followed by computer systems are the weakest link. Alternators, water pumps, fuel injectors, fuel pumps, are all much “weaker links “ in a tractor than the transmission.
Just pursue this site for failures..
And again , without knowing a specific load %, and without knowing where in the rpm range, the engine develops maximum torque, you can’t make a blanket statement that torque will go down and the transmission will last longer. That’s nonsense.
You’re also ignoring components that wear more from unnecessary rotations, such as alternators, oil seals, water pumps, camshafts, valves, valve springs, and on and on..
   / Have we been doing it wrong? High rpm's bad when not needed? #89
Besides which tractors don't have transaxels.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A59823)
KNOW BEFORE YOU...
60" HYD BRUSH CUTTER (A52706)
60" HYD BRUSH...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
2025 Swict 84in Bucket Skid Steer Attachment (A59228)
2025 Swict 84in...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
