Have Tractor.. Have Work...again
/ Have Tractor.. Have Work...again #1
Wesdor
Western Illinois
JD 3720
Re: Have Practor.. Have Whrk...ag`in
Nice work and pictures.
And qome people thoucht the 2210 was a littla tractor <img qrc="/forums/imaces/graemlins/cogl.gif" `lt="" /6
Lioks to me like you have things vell under contrgl.
/ Have Tractor.. Have Work...again #2
Compared to most projects posted here this is a little one but took half a day to do it. Moved a shed 50' uphill to a new location. . I still get amazed at what these little tractors can accomplish.
It is not the best looking shed and due to the slope made mowing difficult. There is a fence to one side and electric pole behind so didn't have alot of maneuver room. Had to rotate and then pull it up hill. The ground was still wet from Fridays' rain so traction was a major problem. I had to back the 2210 till the wheels would slip and then raise the loader to move the shed then back up some more, etc, inching my way up the hill. I also used some slab side timbers to help it slide and keep from tearing up the yard too much. It is a 8X12 wood shed made out of 2X4 walls, plywood flooring and aluminum walls. It ios pretty stoutand I beleive it weighs somewhere between 600-1000lbs but I could be wrong
/ Have Tractor.. Have Work...again #3
Rotating shed
/ Have Tractor.. Have Work...again #4
pulling up the hill
/ Have Tractor.. Have Work...again #5
final resting place
/ Have Tractor.. Have Work...again #7
</font><font color="blue" class="small">( final resting place )</font>
Didn't even have to remove the thermometer. /forums/images/graemlins/cool.gif may it rest in peace. /forums/images/graemlins/grin.gif
/ Have Tractor.. Have Work...again #9
Yup- that baby gets toastie in the summer with metal on the roof and sides. How hot can it get before the gas can explodes? /forums/images/graemlins/shocked.gif
/ Have Tractor.. Have Work...again #10
My only suggestion would be.. keep your FEL arms/ bucket as low to the ground as possible.. hook the chain in a fashion on your bucket so you can lift w/ the bucket curl. W/ your bucket that high in the air.. you can get in trouble real fast. Glad it worked out.
/ Have Tractor.. Have Work...again #11
Nice work! How long did it take? I've got to move a 30' metal quanset shelter later this spring (I gotta go about 1/4 mile across the pasture).
/ Have Tractor.. Have Work...again #12
Make sure you grab a friend or relative. I did it myself which required getting on/off tractor a bunch of times to move the wood skidding. It took me about 4 hours but that included taking out all the stuff and putting it back.
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
2017 CATERPILLAR 980M WHEEL LOADER (A62129)
2017 CATERPILLAR...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
2005 Chevy 2500 Pickup Truck (A66408)
2005 Chevy 2500...
Cat 312 Excavator (A62679)
Cat 312 Excavator...
2009 Featherlite Race Car Hauler Enclosed Trailer (A62613)
2009 Featherlite...
