Hauling Tractor Safely?
/ Hauling Tractor Safely? #21
In regards to:
The ratchet load binders are also superior since the other kind can flip open if you don't wrap enough chain around them
I always twist a piece of wire through the hole in the end of the lever or use a tie-strap to make sure the lever can't flip open. Thats what I always thought the hole was for.
- Rick
/ Hauling Tractor Safely? #22
I am sure that you what to do this in a safe manner. I brought a trailer 18 foot long designed to handle 10,000 lbs or so they say for 1200 dollars new. But in comparison, $1200 to 1800 is cheaper than $15000 for a new tractor. I can not see why you would want to rebuild a trailer to fit your needs when trailers are really cheap as compared to your tractor or your pickup that is pulling the trailer. MHO
Dan L
Thanks again to all of you gentlemen. I got some great advise here. I'm proud to be a member of this forum, that has great people . I'll post when I decide to do something. Kent
/ Hauling Tractor Safely? #24
SteelFan,
I just got a chance to read your thread on Tractor Hauling.
If you are still looking for information on towing, go to
<A target="_blank" HREF=http://www.ford-diesel.com>http://www.ford-diesel.com</A> and read the Towing
discusstion area. You got some very good advice here
on TBN but there is loads more on ford-diesel. No pun
intended! /w3tcompact/icons/smile.gif
Later...
Dan McCarty
Thanks Dan, I'm grateful. Kent
/ Hauling Tractor Safely? #27
I think that single axle trailer is going to be a problem.. remember, the axle is also carrying the trailer weight.
I have a 16' trailer, tandem axle rated at 3k a piece ( but believe they are really 3.5k )
Anyway.. the trailer is a heavy frame, and probably weighs in at around 1700 lbs or so.
My nh 1920 is about 3200 with fluids.. and I imagine my disc is about 600 lbs... I'm within 500 lbs of the 6k limit right there.
One of the axles has brakes....
The load just feels a bit funny... but I am used to pulling my horse trailer any way. Make sure your hitch is the proper class ( III or IV ) also check your tounge...
Dot says you must have a minimum of 2 tiedowns, plus one every so many feet... for us tractor people.. that probably just means 2. I use a chain in front, and a no-cut nylon ratcheting strap in back, rated for 10k pounds... most of hte good ones have break ratings at around 3 times their load ratings.
Small price to pay for your tractor.
My trailer was 1700 brand new... had breaks, and a break-away break controller.. you should be able to find something similar.
Chris
2012 Mini Cooper Coupe (A61574)
2012 Mini Cooper...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
2020 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A61573)
2020 Peterbilt 579...
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
Bomag Roller (A63689)
2025 Swict 66in Bucket Skid Steer Attachment (A61572)
2025 Swict 66in...
