Xfaxman
Super Star Member
- Joined
- Feb 8, 2013
- Messages
- 13,293
- Location
- Guthrie, OK
- Tractor
- Toolcat 5610 G - Bobcat V417 - TORO+Loader
SSQA will work if you add gussets to keep the top lip from bending:
These were made strong from the factory :thumbsup::
View attachment 575996 View attachment 575997
View attachment 575999 View attachment 576000
. Equipment junkyard near by? Abandoned wheel loaders? The measurements (pins, width, etc.) are what really matter.Yes the big loaders sometimes have QA. It痴 a 4 pin system. It痴 nearly identical to the Kubota backhoe subframe mounts except upside down.
Xfaxman is correct about SSQA being suitable IF the attachment plate is gusseted well.
SSQA attachments are widely available but personally I hate the system. I recently sold this NH wheel loader with power SSQA.
I much prefer the euro-style on our other machines. Dropping a bucket or attaching one can be done in the time it takes you to lower the lift arms and reverse direction.
My buddy has a small loader with QA. The sawmills have bigger loaders with QA. I'm not sure how standardized the loader QA is.
I don't think there is a standard. Bobcat had a unique QA for their larger Versahandlers:
View attachment 576118 View attachment 576119
View attachment 576120 View attachment 576124
I have a Deere 210C no backhoe. On paper I thought that it would be great to use as a forklift. So, I spent the time and dough to convert to SSQA. I think it sucks. I'm about $3500 into the project, and lost a noticeable amount of breakout force when trying to get a full yard bucket of crushed limestone out of a pile. And the biggest letdown is still near zero visibility with the forks. Yes, fork visibility is better with the SS forks vs the over the bucket forks, but you still need a spotter for pallets, or anything below 5' off the ground. However, there is another option. A nice pneumatic tire lift truck is money well spent! (still need the tractor for the rare occasion the forklift gets stuck)
View attachment 576138View attachment 576139View attachment 576140View attachment 576141
I don't really have any tractor type uses, I just use it as a loader, and a back blade for spreading gravel. I love the torque converter and reverser transmission, but could see that it might get old trying to plow a field with it.
BTW, those pieces are still sitting around waiting for me, hopefully sometime in the next year![]()
I Skid steer implements are easier to come by. For that reason I may go SSQA.
I started a QA for the loader on my 580B, but it's stalled out lately due to higher priorities - I went with a beefier version of some I saw on Kubotas, most of the parts are 1/2" and 3/4" steel - upper pins will fit into deep "U" brackets, then the 2 lower pins will lock it into the uppers - I built a jig (all 3/4x3 FB) to press 1/2x3 FB into the U brackets, then future implements will just be Case compatible 2-pin mount. If I'm just moving attachments around, no need to use lower pins at all, just "hook-n-go" -
The long radius in the plates is just to clear the curved back of the original 1 yd bucket; other implements (grapple, forks, brush forks, 3ph quick hitch, etc) may not need that. The "U" brackets are only needed on the main loader mounts, any attachments would just be 1-1/2" pins spaced same as original.
Here's a few pics, any questions feel free to ask... Steve
View attachment 576159 View attachment 576160 View attachment 576161 View attachment 576162 View attachment 576163 View attachment 576164 View attachment 576165 View attachment 576166 View attachment 576167 View attachment 576168
