Rake Harley power rake questions!
/ Harley power rake questions! #21
Exactly what is pre-germination and how do you accomplish this? I have never heard of it before. thanks
/ Harley power rake questions! #22
Junk,
I would think that the seed is bathed in water and nutrients X numbers of days/hours prior to laying it down with the hydroseeder. That way when it hits the ground it is ready to drop roots and take off.
/ Harley power rake questions! #23
That's pretty much it. It's better if you do not soak the seeds. I use shallow rubbermaid containers with holes drilled in the bottom then put misting jets above them. I do this frequently so I have a complete setup for doing a few hundred pounds of seed at one time. For a small batch one could use 5 gallon buckets and pour the water/nutrients over the seed a few times a day, as long as you did not let the seed dry out.
Depending on the seed mixture I pre-germinated 3-5 days. I frequently get perennial rye to sprout within 48-72 hours of seeding, bluegrass takes about 6-8 days.
/ Harley power rake questions! #24
the carbide Teeth lasted about 5 times longer than the regular teeth did. I would recomend them to anyone.
/ Harley power rake questions! #25
I have been using my Harley rake to death the last two weeks. What an incredible attachment. When my bottom roller wears out, I will get the carbide replacement roller. The Pro 8 uses the old horizontal bar roller. I can only think that the carbide tooth roller would be better. What an awesome piece of equipment.
/ Harley power rake questions! #26
</font><font color="blue" class="small">( I have been using my Harley rake to death the last two weeks. What an incredible attachment. When my bottom roller wears out, I will get the carbide replacement roller. The Pro 8 uses the old horizontal bar roller. I can only think that the carbide tooth roller would be better. What an awesome piece of equipment. )</font>
Sorry to bump such an old thread, but I have a line on a used one w/ the horizontal bars. Is it effective still or not worth it? It's $1000 w/ new paint.
(50) UNUSED 3'x8' CORRUGATED METAL SHEETS (A64281)
(50) UNUSED 3'x8'...
UNUSED IRANCH IRTPL 10000 LB TWO POST LIFT (A64281)
UNUSED IRANCH...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63689)
2017 Yale GLC050VX...
2019 PETERBILT 567 TRI/A DUMP TRUCK (A59912)
2019 PETERBILT 567...
1995 Landoll 55 Ton Trailer (A60352)
1995 Landoll 55...
2014 FREIGHTLINER CASCADIA 113 S/A DAY CAB TRUCK TRACTOR (A59912)
2014 FREIGHTLINER...
