Hard wired inverters
/ Hard wired inverters #1
Justaplain
ECNY
DK35
Is there a place for these on CUT's. If not, why not.? Sounds reasonable to me. Pro's and con's please. bcs
/ Hard wired inverters #3
The major problem with putting one on a CUT is that it would need to be weather proof and those can be hard to find and a bit expensive. If you put an open model on it would surely get wet from somewhere.
/ Hard wired inverters #4
What you want to run is most important. Remember, you're converting 12 volts to 110, therefore, a 1,000 watt inverter will produce about 9 amps at 110 volts, but will require a 12 volt battery draw of 80+ amps. My alternator on my 25 gross HP tractor only puts out 20 amps, and the battery is a relatively small 450 cca battery. To run a 15 amp circular saw would require a 2000 wat inverter and you could only get a limited amount of usage on it. Even a 1,000 watt inverter would be tough on your battery and not give you much power.
A portable generator would not cost a whole lot more and give you 3,500 - 5,000 watts CONTINUOUS power and would be far more versatile.
If you just want to run some tools, once in a while, you can invest in an 18 amp RYOBI package for a few hundred dollars. An inverter will cost that much.
Thank you gents, that saved me some money. Iwas thinking of hedge trimmers, limb saws and maybe a drill. bcs
/ Hard wired inverters #6
One of the JD lawn tractors has a built in AC alternator or inverter. Not sure which one it has.
/ Hard wired inverters #7
I guess that is so you can set a little tv on the hood and watch the game while you mow /forums/images/graemlins/smile.gif
/ Hard wired inverters #8
I have had a 1200 watt Tripp Lite inverter on my service truck for the past 7 years. Wouldn't want to do without it. Run grinder, wire brush, sawzall, portable band saw, & skill saw and 1 HP air compressor. Does a good job on all except the skill saw. If you let the blade bind a little, fuses blow.
This is not for continous use, but pays for itself shortly in my business. Weighs 38 lb & cost me 559.00
Just bought Coleman PowerMate PMP1200 this week. Weighs 7 lb, 1200/2400 continous/surge. 120.00
Broke it in drilling 1-1/4" holes 14" deep in pine stumps with a Milwalkee hole hawg drill. 5 holes per stump. After drilling 25 holes, it was not warm enough for the cooling fan to come on.
I think it is going to be alright.
PS: I do have 2 batteries in my truck.
/ Hard wired inverters #9
BJ's wholesale has 1000watt /2000 surge watt and 800watt /1600 surge watt inverters for $89 and $55 respectively.
I have the 800/1600 Coleman Powermate and it says it will run drills, 1/4 hp pumps, small saws, bench grinders etc. All I can say is I tested it and it ran my 35" bigscreen TV and cable box, a light and a radio. All at once. I don't think hedgeclippers, trimmers or your drill would be any problem at all.
I would not hardwire it o atractor because of moisture issues I would just use the alligator clips on the battery terminals and bungee cord it on the FEL or weight rack
/ Hard wired inverters #10
Neal, I just ordered a Coleman Powermate PMP 2000 inverter (actually bid on it and won). Among other things I also planned on being able to use it to recharge the batteries for my cordless tools. I thought to check my owners manual for one of my cordless tools tonight (I don't have the inverter yet). I probably should have thought to check the manual before I bid on the inverter /forums/images/graemlins/blush.gif. Anyway the manual says "Do not attempt to use a step-up transformer, an engine generator or DC power receptacle". I'm not sure if the inverter falls into any of those catagories or not. I am wondering if you or anyone else has recharged their cordless tool batteries this way?
Spence
/ Hard wired inverters #11
They say have the wattage requiremets listed on my Coleman inverter for rechargeable drills. I don't think their will be any problems. I have used it to charge my cell phone with no ill effects.
/ Hard wired inverters #12
Be cautious of DeWalt rechargables with an Inverter. I almost set my house on fire with one. I'm not sure exactly what the interaction was , but the result was a sizzling hot, venting battery. My new Makita gear, on the other hand, works fine.
/ Hard wired inverters #13
Spence,
That is something I have not tried. I do know that some things can be sensitive to the modified sine wave these inverters put out. Most of my use is with brush type power tools plus the compressor 115 volt, 10 amp motor. These all seem to operate normally. I sometimes plug in a fan, which works fine but has a little whine in it.
This is also on my TrippLite inverter, but I suspect the Coleman PMP2000 is the same type current.
2021 UTILITY VS2DX 53x102 T/A DRY VAN TRAILER (A59914)
2021 UTILITY VS2DX...
New/Unused Hercules ATV Sprayer (A65583)
New/Unused...
40' Used Container, High Cube, Single End Doors (A62679)
40' Used...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
Massey Ferguson 285 Tractor w/ Loader (A66285)
Massey Ferguson...
