hard to reach grease fitting
   / hard to reach grease fitting #11
Replace the zerk with a small barb fitting or compression fitting. Run hose or tubing to an easier to reach place and add a zerk to the end. That’s basically how we do it on our automation equipment. Offen we run multiple grease points into a manifold so the operator s only need to grease one point on the machine.
   / hard to reach grease fitting #12
Can't say for sure without seeing your pto guard but quite a few of those plastic pto guards you can release a lock then give a twist/turn on the guard and it will pull back completely exposing the u joint or cv joint. B
   / hard to reach grease fitting #13
Who designs this stuff? it's like the automakers that make it so you need to disassemble half the vehicle to change a bulb.
   / hard to reach grease fitting #14
On my finish mower, the zerk fittings are burried under the protective metal plates, so Land Pride attached rubber hoses to where the zerk would fit that are about a foot long, then the zerk fitting is attached to the end of the hose. One broke on me and it turns out that the flexible hose that comes with a grease gun is the exact same threads, so I replaced it with that. Instead of trying to get the grease gun to your zerk, why not extend the zerk fitting out farther with either a flexible hose or a solid tube?
   / hard to reach grease fitting #15
That sounds like a novel idea, so re you talking about something like this>>>>>>>> https://www.amazon.com/Anderson-Met...NPT+Connector&qid=1559084366&s=gateway&sr=8-1
I failed to mention that the grease fitting is on my brake petal shaft, I forgot what size it is, but I'm sure it's the small zerk, are there barb fittings that fit the small zerk?
   / hard to reach grease fitting #16
Well you could say that's my fault, the under side grease fittings were easy til I added a skid plate, you know how it is sometimes, when you cure one problem you end up creating another one.
   / hard to reach grease fitting #17
Clever but on my brake pedal shaft I'm quite sure those threads are smaller then a grease gun hose, of coarse with pipe threads it adds more complication.
   / hard to reach grease fitting #18
   / hard to reach grease fitting #20
OK, on my tractor the main front axle 'pivot' is down under and hard to access.
SO, I added some 1/8 piping to bring the zerk up to a handy accessible location.
(LOL, my old bones simply do not allow me to crawl under to grease that Zerk)
Once I had purged the extension clear greasing was a snap.
You simply have to think outside of the 'box'.
CATERPILLAR 320GC EXCAVATOR (A51242)
CATERPILLAR 320GC...
2016 SDLG L948F WHEEL LOADER (A51242)
2016 SDLG L948F...
IH 686 Tractor (A50514)
IH 686 Tractor...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
