hard to reach grease fitting
   / hard to reach grease fitting #21
That site does have what I think will work, but a little pricey I was hoping for a $20.00 solution instead of $40.00+S&H, I gotta do some hemming and hawing on this.
1st thing is this>>>> 1/4-28> Grease Fitting Thread Adapters - GreaseExtensionHoses.com
2nd thing>>>>>> 9o Zero Clearance Elbow - GreaseExtensionHoses.com
3rd thing and most expensive>>> Grease Fitting Relocation Hose - Ready to Install <<<<<I need 12" but I want 14", that will leave me 2" of multinational errors that sometime follow me. I didn;t check the S&H I got scared already.
   / hard to reach grease fitting #22
That sounds like a novel idea, so re you talking about something like this>>>>>>>> https://www.amazon.com/Anderson-Met...NPT+Connector&qid=1559084366&s=gateway&sr=8-1
I failed to mention that the grease fitting is on my brake petal shaft, I forgot what size it is, but I'm sure it's the small zerk, are there barb fittings that fit the small zerk?
More like this. Google grease manifold, the ones that came up were not real cheap but I think Lincoln has a lot of this type of stuff.
Here’s a good link.
Remote Grease Lines and Fittings >> Lube Control
   / hard to reach grease fitting #24
Thanks, I didn't know Lock N Lube had affordable grease hose extensions, I have their grease coupling and like it. So I went to their site but not sure what to get so I sent them an email. I want to get this hose but not sure what the threads are on the 90* end>> Grease Fitting Relocation Kit | LockNLube - LOCKNLUBE
First I dont know what threads are on my brake petal, I'm quit sure they'r small but are they 1/4-28 or metric, if they are or aint I dont know if I need these other to items..............
M6x1 metric (m) x 1/4"-28 NPT(f) - LOCKNLUBE
1/4"-28 Taper (m) x 1/8" NPT(f) - Straight - LOCKNLUBE
Blue Concrete Test Shed (A49461)
Blue Concrete Test...
2019 FORD F-150 (A50854)
2019 FORD F-150...
C13 MOTOR (A50854)
C13 MOTOR (A50854)
2017 DITCH WITCH RT30 (A51243)
2017 DITCH WITCH...
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A51222)
2015 INTERNATIONAL...
2014 STEPHENS CRUDE (A50854)
2014 STEPHENS...
