hard to reach grease fitting
   / hard to reach grease fitting #11
Replace the zerk with a small barb fitting or compression fitting. Run hose or tubing to an easier to reach place and add a zerk to the end. That’s basically how we do it on our automation equipment. Offen we run multiple grease points into a manifold so the operator s only need to grease one point on the machine.
   / hard to reach grease fitting #12
Can't say for sure without seeing your pto guard but quite a few of those plastic pto guards you can release a lock then give a twist/turn on the guard and it will pull back completely exposing the u joint or cv joint. B
   / hard to reach grease fitting #13
Who designs this stuff? it's like the automakers that make it so you need to disassemble half the vehicle to change a bulb.
   / hard to reach grease fitting #14
On my finish mower, the zerk fittings are burried under the protective metal plates, so Land Pride attached rubber hoses to where the zerk would fit that are about a foot long, then the zerk fitting is attached to the end of the hose. One broke on me and it turns out that the flexible hose that comes with a grease gun is the exact same threads, so I replaced it with that. Instead of trying to get the grease gun to your zerk, why not extend the zerk fitting out farther with either a flexible hose or a solid tube?
   / hard to reach grease fitting #15
That sounds like a novel idea, so re you talking about something like this>>>>>>>> https://www.amazon.com/Anderson-Met...NPT+Connector&qid=1559084366&s=gateway&sr=8-1
I failed to mention that the grease fitting is on my brake petal shaft, I forgot what size it is, but I'm sure it's the small zerk, are there barb fittings that fit the small zerk?
   / hard to reach grease fitting #16
Well you could say that's my fault, the under side grease fittings were easy til I added a skid plate, you know how it is sometimes, when you cure one problem you end up creating another one.
   / hard to reach grease fitting #17
Clever but on my brake pedal shaft I'm quite sure those threads are smaller then a grease gun hose, of coarse with pipe threads it adds more complication.
   / hard to reach grease fitting #18
   / hard to reach grease fitting #20
OK, on my tractor the main front axle 'pivot' is down under and hard to access.
SO, I added some 1/8 piping to bring the zerk up to a handy accessible location.
(LOL, my old bones simply do not allow me to crawl under to grease that Zerk)
Once I had purged the extension clear greasing was a snap.
You simply have to think outside of the 'box'.
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
3 pt Aer-Way (A50514)
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
Pallet Fees (A50774)
2018 PETERBILT 567 (A50854)
2018 PETERBILT 567...
71063 (A49346)
71063 (A49346)
