Hard surface rod
/ Hard surface rod #11
So I often see hardfacing run in various hatching patterns...my understanding is that it helps trap rock or dirt on the sides of the implement so that the dirt/rock that is moving wears against the trapped material instead of the bucket or implement. So would there be any point in using beads of hatch patterns with a regular rod to do something similar, or would you not get the same effect as with the harder rod?
/ Hard surface rod #12
The hardfacing Ive seen is a large flux coated bronze rod containing small chips of tungsten. This is applied much like the brazing process. Ive seen it on the bottom of horse shoes - 3 one inch areas one at the front of the shoe and 2 at the opposing ends. This gives a horse traction when walking over pavement. Without it pavement is very slippery with just a smooth shoe.
/ Hard surface rod #13
Every is inclusive of all times, items whatever while each refers to individual occurrences, items etc. so if you have a dollar for every, that means exactly one dollar for all occurrences while if you get a dollar of each then you get a dollar for each occurrence or a whole heap a dollars.
Are you going to point out this grammar error every time or each time you see it? :)
/ Hard surface rod #14
Same effect, just that the build-up weld metal will wear faster because - wait for it - it's not as hard.
But for us here with our tractors it would be fine.
/ Hard surface rod
Thanks Every one . Although I could likely run the rod , Really have nothing to run / burn it onto ??? Not even sure what My Dad had it for . Looks like Maybe15 to 20 rods are missing out of 1 corner . Guess I could weigh it to see how much it weighs , Likely just take the storage box and put it box on the top shelf for another 20+ years .:D
Fred H.
/ Hard surface rod #16
So the instructions on the medicine bottle says, "Take a pill every three hours". What should I do?
When I looked up "every" in the dictionary, it says "1. each, individually and separately"
/ Hard surface rod #17
I think that's the definition that was giving me a headache.
/ Hard surface rod #18
Many times, esp. on the internet, folks have to prove how their a step above everyone else. It's just their method to make them feel important to others. Usually don't have a lick of common sense either!
If they were half as smart as they think they are, they'd be twice as smart as they really are.
/ Hard surface rod
The Last Sentence Says it All !!! :thumbsup:
I like that last sentence D2 , Going to borrow it . Thanks for Sharing . ;)
Fred H.
Butler MFG Water Tanker (A61307)
Butler MFG Water...
2011 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A60736)
2011 HEIL TRAILER...
Woods DS8.50 (A60462)
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
CATERPILLAR 924F WHEEL LOADER (A59823)
CATERPILLAR 924F...
2015 HINO 195 16FT BOX TRUCK (A59905)
2015 HINO 195 16FT...
